The plugs on the 18.97 should be 3.5mm as well as the LMT unless you got a High Amp version.
Hi cory
No i did not get the hi amp version. I happen to have a complete set of 3.5 mm plugs. What about the wire if it does not fit into the plug, can i just solder it to the end ?.
