glassdoctor
TEAM FUSION
glassdoctor's Avatar
03.24.2007, 01:43 AM
Nevermind the above pic..... you already said the stock bearing is 10mm.
Also I measured the stub on the kyosho which is right about 10mm. It's just a hair under 10 then tapers to just over 10. I wondered if you could use a spacer sleeve to make the stock bearing fit right on the kyosho... and fit at least part way onto the fat part of the stub. Just a little sanding on the stub and the bearing would fit. That would let the stock outdrive fit farther into the diff... maybe enough to work.
Make sense???
The problem then is that it's still a mod1 gear and you are using a MM. 1/8" bore mod1 gears are a pain... maybe Mike could hook you up with a spacer so you can use the 5mm gears.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
