BMW M Power!
03.25.2007, 01:33 PM
Originally Posted by Serum
You came to the wrong place with that argument..
Most accurate post if I ever saw one. :027:
Conversions is like 99.9999999999999% of what this forums about. I'm pretty sure more people have converted Revo's and LST's and stuff than an actual electric trucks.
03.25.2007, 09:51 AM
maybe a mini lst if you keep it stock they run great and for about 200 and they are alot of fun but if you start to upgrade it be prepared to hold on to your wallet.
MaxAmps Marketing Manager
03.25.2007, 08:37 PM
GUYS GUYS........don't get me wrong I live to convert.......heck three of my planes are converted slimmer kits...........I just don't want to stick a ton into two cars........I do like the Associated T4 but yeah to keep cost down I think the stampede/rustler angle is the way to go..............plus I have two outlets in town for parts for them..........Now I'll do mine with BL but what do you think the step son will say when I smoke the crap out of his brushed set-up..............HAHA.
TEAM FUSION
03.25.2007, 09:04 PM
Well.. the Pede/Rusty are super cheap and you got the hookup of batts... so it wouldn't be too bad with MM systems.
That's about $360 per truck plus your lipo packs and whatever upgrades you want... tires, etc... and a few bucks for a couple steel idler gears.
And you can sell off the stock electrics that come in the box...
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
03.25.2007, 09:19 PM
I don't know about the rest of you, but it seems the electric-specific vehicles don't seem as solid or built as sturdily as the Nitro counterparts. My son has a Pede and it works well and all, but for a speedy and/or powerful R/C, a Nitro roller conversion seems to be the thing to do, despite the trials and tribulations of the conversion process. Of course, anything can be made bulletproof to handle high power with enough $$$...
03.26.2007, 01:04 PM
I agree to a certian extent, the nitro's do seem to be tougher toa certian extent. But there is an electric stadium that is as tough as any nitro, thats an associated T4. It has the GT diff and is all around stable with brushless power (except for on 3s:020: ) and the only parts i ever broke were my doing not from the power. I have a t4 RTR as well and run it for a year before i stepped up to the team, I never adjusted or rebuilt the diff in the time i run it. The T3 is good as well and in some cases may be better, the suspension seems to be tougher than the T4 and i have had one for four years and never rebuilt the diff. The reason i mentioned the diffs so much, is because i got friends who race XXX-T's and with stock (old style)ss5800's, they rebuild their diffs every 5 runs, because from the 6th to the 8th run, the diff will fail
RC-Monster jumper
03.27.2007, 01:04 AM
i havent had my diff fail and i have about 25 runs with higher power then a 5800ss
i do however have the mf2.
my diff is still silky smooth.
03.29.2007, 04:43 PM
I love the MF2,a 2wd electric stadium truck is hard to beat for fun,low maintenance and low running costs.i think they're perfect for someone who wants a fun basher but doesn't have a huge amount of time to put into RC,plus they're relatively easy to achieve very high speeds from.And they're pretty hard to break compared to a MT.And they handle so well,a good MF2 is a joy to drive(kit settings are pretty dialed since it's a Losi).
I do need to do regular diff rebuilds though,any mistake adjusting the diff when you're running a lot of power and the diff gear will melt,not just too loose,if it's too tight it will over heat when it diffs out.that said,diff gears cost pennies and it's a very quick job.I have a 7075 hard anodised diff gear for the genII tranny if i can figure out the diff ball size it uses.I always carry a spare complete tranny when i run anyway,and rebuild the other one later.once you get the knack of building the diff and adjusting the diff and slipper they last fairly long though.
here's mine after a winter overhaul, all ready for spring time:024:
If it's a 1/10 4wd there's not too many options(unless you want a buggy) other than the MT2 18SS,which are great but are tight for space,conversions are usually an excercise in packaging.
the schumacher havoc is 2wd 1/8 truck that has a bullet proof ball diff and transmission,i've always thought someone should convert one of those.
TEAM FUSION
03.25.2007, 09:29 PM
I think the pede/rustler do have some weak spots.. but they are not too difficult or expenxive to fix.
I agree totally... the nitro versions are normally built tougher. A classic example.. probably the best one... was the HPI MT 1/10 truck. The original electric truck was a horribly fragile piece of crap. But then they redid the whole truck and came out with the nitro version. For some reason they never redesigned the electric, but dumped it instead.
My cousin still has a like new electric mt.... you almost have to treat it like a vintage r/c...
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
BMW M Power!
03.26.2007, 12:28 AM
Yes, I think the Nitro's are built better because of the whole "Nitro is faster" mindset which means harder impacts, etc. However, I think as soon as companies start including brushless systems standard (Losi doesn't count though, since the SS4300 isn't exactly a bullet, and thats a race truck). But once brushless systems are included in stuff like the E-Maxx (or equivilant truck) and such, things will get much tougher.
However, the Stampede and Rusty are the most durable RTR electric trucks if I ever saw one.
Jam, I'd say you can go with a MM4600 oor 5700 on 3S lipo, while keeping the young one to 2S lipo with the 4600 or 5700 if you think he's up do it. This can also be controlled with timing, punch control, and start power. Later on, an easy speed increase will just be an upgrade to 3S.
However, if you do want a T4, a buddy of mine is selling a NIB Factory Team one for a (very) resonable price - I'm actually selling it for him, its in my closet right now lol. Drop me a PM if interested.
03.26.2007, 01:15 AM
Originally Posted by BP-Revo
...This can also be controlled with timing, punch control, and start power. Later on, an easy speed increase will just be an upgrade to 3S....
Can't forget the EPA adjustment on your radio...
03.26.2007, 01:18 AM
I think alot of people forget that the new XL5 pedes are alot better then they used to be. The problem with getting any 10th scale electric other then pede/rusy...nothing else has the revo type slipper. And lets face it. That revo style slipper is the only slipper on the market that actually works for high powered brushless.
Also. I wouldn't waist your money on a MM motor. Get the speed controller and a lower kv motor. Something in the 10s or even 12s range. I've tried pretty much every brushless motor you can fit on a pede. Anything higher then 3100kv will just be a pain in the ars.
03.26.2007, 01:21 AM
You don't think the 4600 on 6 cells is tame enough? I was planning on upgrading my son's pede with the MM and 4600 motor...
03.26.2007, 01:59 AM
4600 is waaaaayy to high kv for a pede. Get the lowest kv S can sized motor Mike has. I'd recommend around 2400kv but I doubt you're lucky enough to find anything that low. If he still has any 2400kv Lehner Basic XL then snatch it up. Whatever you do, don't waist your money on a mm motor. Even the 4600 is WAY too high rpm. Believe it or not, that 2400kv will have more power, have MUCH better run times, and run cooler. With those higher kv motors its like they are lugging every where they go. Don't even worry about those lower kv motors not being fast enough. My pede has a 2600kv in it and I clocked it at 60mph with 3cell, and still had plenty of power in reserve. The common misconception that pedes need a 4000+kv motor to be fast is a fricken myth and it needs its own sticky on the subject. Hey, you should see my little bros pede go that has 1200kv lehner basic xl on 3cell. It's not exactly a bullet, but it'll beat the waller out of a stock pede. And go for over an hour between battery changes.
03.26.2007, 02:56 AM
Hmm. I didn't bother to look at the tranny ratios so I just assumed the 4600 would be ok. The 4600 in the Jato stays cool so I figured it would work ok in the Pede. You know what they say about assuming...
| Thread Tools |
| Display Modes |
Rate This Thread |
Hybrid Mode
