AAngel
03.26.2007, 01:32 PM
When I we first did the conversion on a Losi 8ight with MM controller and Feigao 8XL, we were using a JR XS3. It did the same thing that you are having trouble with. Up close, everything was fine. Once we put it out on the track, it glitched like crazy. We had the motor on the passenger side of the buggy with the esc right next to it, just in front of the rear support at the back of the buggy. We had the receiver at the front of the buggy on the driver's side. This was as far away from each other that we could place the esc, motor, and receiver. It still glitched. Ultimately, we had to put a Spektrum radio into the buggy. When we did this, all problems disappeared.
Defcon
03.27.2007, 05:20 AM
The motor is mounted on the drivers front corner and the receiver is just in front of the rear diff mount between the battery and the drive shaft.
I hope it's not the radio. I was thinking it may be the motor to esc connections so I ordered some 4mm male bullet connectors to try instead of directly soldering the wires with a female sleeve.
I also plan to try a different receiver and if that dosent work I will borrow a radio and receiver to try.
