Jasper
04.01.2007, 12:24 PM
I need the battery trays for my new J-revo design.
The design is based on the stock chassis. The bendings are similair to the stock chassis. I will use an OFNA center diff. The diff is mounted close to the rear. So there is enough space to mount the motor in the middle of the chassis. The servo mounts are designed similair to the stock chassis. The battery trays will be hanging, behind the servo mounts, at boths sides, under the chassis.
The Kyosho trays can take 7 cells max. I want 8 cells. So I am still searching!
