jimbob
04.06.2007, 01:07 PM
yes :026:
well this will require the suspension to be set low... but this is the design i have current come up with...
either this or a new motor mount will also be required as this was the only was i could see to make the 50t sput and 14/15/16t pinion meet
jimbob
04.09.2007, 04:04 PM
so stock gearing is 21.71:1
with 50t spur and 13t pinion on diff it is 11:1 (dunno if you would help me on this)
if so i would plan to run the 44t spur and a 23t pinion i should get a 5.5:1 ratio :027:
why you ask well at 27500 rpm with stock tranny it does what 25mph so at 400000 it must do around 38mph
so if the ratio is around 4:1 then i am hoping to run an out-runner brushless motor for more torque (5 to 8 times as much as a inrunner) and they run at about 12,000 rpm lets say so that would be the same as 48,000 rpm on stock tranny so 45mph :004:
these are very rough estimates.. but im looking at different possibilites, like you said the gearing would be high with this set-up
