glassdoctor
TEAM FUSION
glassdoctor's Avatar
04.14.2007, 11:26 PM
Welcome to the forum...
I'll hit a couple things quick... others will have input too... and you will find plenty of info here if you do some reading.
1. You need to run a plastic center gear believe it or not. Steel gears will destroy the pinions.... the Kyosho plastic gears work great.
2. I don't know off hand which parts fit for the xray, or if there is motor mount available yet, but I know someone here has doen an xray...
3. The best combo for under $300 is the Mamba Max esc and a Fegiao 8XL. That's about $225 and you also need a ubec (voltage regulator for rx/servo) which run $15-40.
Chassis flex should not be an issue any more than nitro... ?
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
