sikeston34m
sikeston34m's Avatar
02.25.2009, 11:50 PM
Have you ever seen a 2826 up beside a 4120?
How many watts do you plan on shoving through there in "bash" mode?
TexasSP
Something, anything, nothing
TexasSP's Avatar
02.25.2009, 11:44 PM
Those aught to not break....
www.cubicle101.com
trev3813
Dsm needed
trev3813's Avatar
03.07.2009, 11:56 AM
How about this for a power plant?
http://www.hobbycity.com/hobbycity/s...rushless_Motor
Bar-A10
04.10.2009, 02:07 AM
Im getting ready to build a Revo base 6x6 here soon how this 6x6 do?
04.10.2009, 09:41 AM
It performs well, plenty of traction and it will go thru or over just about anything. It floats on tall grass, kinda funny for something that weighs 13-15lbs. Have fun with the revo, those bulks look like they will need some work to allow for a pass thru diff.
hellboy_044
hellboy_044's Avatar
06.11.2009, 12:54 PM
hi anymore news on your truck looks good
hellboy_044
06.24.2009, 07:54 AM
Come on you can't just stop there we want to see more ?????
hellboy_044
06.24.2009, 08:29 AM
I see your running a 1/4 servo how much power has it got and at what volt's ?? I've been look at one that put's out 33kg as im doing a e-maxx 8x8 and 1/10 servo's are ok but think i need more than 24kg for each set of wheel's
06.24.2009, 10:18 AM
The 1/4 scale servos work very well. They are much more powerful than any 10th servo I have used.
I still need to completely go thru this truck, and change it up quite a bit. I have longer chassis to fit, al center bulks to modify and install, and a new emaxx 2 speed wide ratio tranny to put in. When I get the lst based 6x6 done I will focus my attention on this truck.
e-maxx's
hellboy_044
e-maxx's - 06.24.2009, 12:30 PM
I have a truck like your's in my work shop i started it about 2yr's ago it's got 4 x 700 drill motor's to go in it and jumbo kong wheel's no body as it got put to one side when i started my E-maxx 8x8.
I will add a pic when i can
just need to sort the steering out and a new body and some new battery's and it's done for now .
Just a short cilp of the 8x8.
I also have a E-maxx 6x6
and a 4x4
I want to have ago at a 10x10 with 6 wheel steer and 4 motor's when i get the rest done.
You never know if it can be done till someone has.
Bar-A10
06.24.2009, 09:17 PM
I have something like that in planing stages
hellboy_044
06.25.2009, 07:37 AM
Sound's good how's the 6x6 coming ?? I need to get a milling small machine before i can start the 10x10 .
hellboy_044
07.30.2009, 06:08 PM
well not much going on here now what's happened to the e-maxx 6x6 ???????????
07.30.2009, 07:21 PM
Still waiting on me... I have the new chassis rady and need to get the al center bulkheads cut and welded. Might wait till the fall, as it is a tad warm here right now...
hellboy_044
01.17.2010, 01:24 PM
anything new happening on the truck ??????
