Serum
Serum's Avatar
06.18.2007, 02:25 PM
I stopped waiting for the balancer to stop blinking before i charge the packs; just charge them with the blinking lights, the balancing process goes faster when charging. (or you don't need to wait for it)
rchippie
rchippie's Avatar
06.18.2007, 02:26 PM
Thank's for the tip rene. Did you find out if you had any of what we talked about ?.
REAL MEN RUN BRUSHLESS
rchippie
rchippie's Avatar
06.18.2007, 04:03 PM
i just talked to jack at HYPERION & he said there is no added benifit of balanacing my packs everytime (per say ). He also said i could make up a cable that goes from the charger straight to the battery, & charge them that way & balance every 4 or 5 charges. My ? is if i charge them without the balancer is it safe ?. He also said the battery would charge faster not being connected to the balancer. I dont think im comfortable doing that. Any thoughts ?.
Serum
Serum's Avatar
06.18.2007, 02:29 PM
not yet; what is your plan? perhaps i can make you something.
with you batteries Just tell them who's in charge.. (and with these words , the price for the 'worst joke of the day' is already taken by .....)
rchippie
rchippie's Avatar
06.18.2007, 02:40 PM
LMAO :005:
I'm making something very similar to what the mbx 4 had for a fan mount. I have exactly what i want made from aluminum but was going for the BLING BLING factor of CF LOL :005: .
It it a mount the looks like this with the fan mounted on the horizontal part & the vertical part is only about a 1/2 inch or so wide so i can mount it to the mount i made to connect it to my ESC mount. . The fan mount will screw to the reverse mount i made. I hope this makes sinice to you ?.
FAN
_______
l
l
l
Serum
Serum's Avatar
06.18.2007, 02:41 PM
I think i still have the mount you used.
rchippie
rchippie's Avatar
06.18.2007, 02:46 PM
I already made another one of those in aluminum. I was thinking abount making one out of CF.
06.18.2007, 05:44 PM
You are probably ok with not balancing everytime, but why not do it? It's not going to hurt anything and you can be sure that your pack will always be balanced. I balance while charging all the time. Any decrease in charge time by not using a balancer is negligible. Technically, since the bal does discharge at a low rate, charge time does increase, but is so small that it really is not worth mentioning IMO.
rchippie
rchippie's Avatar
06.18.2007, 06:27 PM
I agree with you & i feel safer using the balancer evertime.
jhautz
jhautz's Avatar
06.18.2007, 06:34 PM
I dont balance every time. I have more chargers than balancers so I just balance every couple charges or so. I rarely find anything that take more than few minutes to charge with the exception of some of my older 10C packs that get pushed very hard and tend to go out of balance more. But even they arent that bad.
to make it...
or break it...
Silent...But Deadly
06.18.2007, 06:43 PM
Well, if you don't have enough balancers, that's another thing. I only have two chargers, so I have two balancers. My Hyperion charger acts funny though no matter what lipo battery I use. Once the voltage gets to ~4.1v/cell, the charger errors out ("output voltage too high"). The only way I can get it to not do that is to lower the charge current to about 3.6A. Weird. So, I use that for all my NiMH and the Xtrema for the lipos.
rchippie
rchippie's Avatar
06.19.2007, 11:10 AM
Are lipo's like nimh in respect to when the charger shows they are finished charging you have to use them right away to get the best performace, or can i use them two or 3 days latter ?.
rchippie
rchippie's Avatar
06.22.2007, 04:33 PM
what should the volatage be on a 4s 8000 pack be when fully charged ?. Thank's
jhautz
jhautz's Avatar
06.22.2007, 04:41 PM
4.2v per cell.
16.8v total.
to make it...
or break it...
Silent...But Deadly
rchippie
rchippie's Avatar
06.22.2007, 04:46 PM
Originally Posted by jhautz
4.2v per cell.
16.8v total.
Thank's thats what i thought. My charger shut off before it got to 16.8. I just called maxamps & they said sometimes that can happen. He said it was safe to put it back on the charger . I guess it might have false peeked or something. I did balance them before starting.
