steveo
09.09.2007, 12:12 PM
hey put a pic of that esc on rumrunnerracing.com(fe boat forum) guys are always looking for big power like that
lutach
lutach's Avatar
09.09.2007, 12:46 PM
It's there.
09.09.2007, 12:55 PM
I like this ESC as well despite the large size. However, the only thing that would make me hesitate to purchase something like this would be the relatively small supply and possible difficulty in obtaining parts for service down the road. Of course, if it was around the same price as the MM, then it wouldn't be an issue. ;)
No matter what, I like where you're going with this (except the fan) and am curious how well this progresses.
lutach
lutach's Avatar
09.12.2007, 04:34 PM
The engineer will send me a 100A controller that handles 7S lipos. He said he didn't have the FETs for a 10S controller. I also posted thin information in rumrunnerracing.com and one member there mentioned he has a true 150A continuous controller and he said mine will only do 95A. Here is the link: http://www.rumrunnerracing.com/fefor...ad.php?t=23246 please look at the 17th and 18th post. I might not be as smart as that guy, but I know the copper traces and FETs will never be able to put out 150A of continuous current. It would also take a really complex cooling system to keep a FET cool at 150A continuous duty. Like I said in that thread, I don't want to sound rude, but I'm doing something for us car guys and I can't have someone ruin this right now.
GriffinRU
09.14.2007, 11:40 AM
Interesting discussion down there...
Serious gaps in calculating and estimating FET's performance and do not worry about PCB traces, for serious currents adding copper bars solves the problem.
Most FET packages (TO220/262...) not rated to deliver what die itself can.
lutach
lutach's Avatar
09.14.2007, 12:09 PM
Do you think that guy is for real with his true 150A continuous controller? What he basically said is that my controller is a 95A controller. I'll just have to wait and put out the numbers.
snellemin
2 KiloWatt RACER
snellemin's Avatar
09.12.2007, 04:57 PM
There is always an expert somewhere that swears to know more by just looking at picture.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
09.14.2007, 11:43 AM
Is there a reason why FETs don't have an electrically insulated metal "insert" to help cool them? Adding a heatsink to the epoxy package definitely helps, but it IS plastic after all.
lutach
lutach's Avatar
09.14.2007, 12:11 PM
I know some companies that makes MOSFETs with metal casing, but it is mainly used in military applications and it can be somewhat expansive.
GriffinRU
09.14.2007, 12:15 PM
You do not want to do that if you plan to sink lots of Amps. Current design is great for given applications and it is much easier to deal with insulation of the tabs outside the package, while utilize FET's substrate as one connector and a heatsink at the same time.
There are 7 pin Dpak packages and direct-on Fet packages which are designed to maximize heat and current transfer.
The best way is to combine high-speed heatsinking (Copper) and low-speed (Alum), then ceramic can be utilized as long as it is very thin. And I think that is the idea behind all packages.
rchippie
rchippie's Avatar
09.14.2007, 12:26 PM
So when we mod the quark are we better off using a copper or aluminum heat spreader ?. And would it better to have a heat sink made from copper also ?. Thank's
REAL MEN RUN BRUSHLESS
GriffinRU
09.14.2007, 12:33 PM
I am working with Mike on Brass-Copper heatsink for Quark, updates will come pretty soon :)
I haven't seen nor touched his controller, so I do not know yet.
I thought we did the estimate with you before.
rchippie
rchippie's Avatar
09.14.2007, 12:39 PM
Thank's artur for the heatsink update. Whats your opinion on the heat spreader for the quark, copper or aluminum ?. Artur how have you been ?.
09.14.2007, 12:30 PM
Since these ESCs don't produce a TON of heat, Al is fine IMO. I was just curious about adding metal tabs because it seems like these ESCs are getting large for high current. I figured if say, 10-12 FETs were intergrated into one long package with adequate cooling and terminals, the size could be reduced and manufacturing simplified.
Also, Al is lighter, cheaper, easier to obtain, and easier to work on.
snellemin
2 KiloWatt RACER
snellemin's Avatar
09.17.2007, 10:53 AM
I have a question. Just for kicks, would a mamba esc "brain" board work with the your mega esc? That would be a nice mod as well.
But as of the neutral position, could dragbrake be applied at that position?
