crazy4wdracer
11.05.2007, 10:03 PM
yeah, I run a 645 too.
Thank you guys SOOOO much for the help I really appreciate it!
BP-Revo
BMW M Power!
BP-Revo's Avatar
11.06.2007, 12:29 AM
My CCBEC is set to 6.2v. I use a Hitec 5955TG, which is very similar to the Hitec 5995TG, which is rated up to 7.2V. The 6.2v should give me a little extra power from the servo, resulting in about 350oz of torque.
Running at least 6V will help tons with servo speed, response, and torque. 5v is ok, but you don't get the most out of the servos...
tashpop
11.06.2007, 06:18 AM
the castle link from the mamba max is different from the mamba25? just wondering, because i haven't changed my bec settings yet, and i have the mamba max cable.
Dafni
Dafni's Avatar
11.06.2007, 07:28 AM
Yep, the cable you use on the MambaMax is just a USB cable. The MambaMax has a USB port. The Mamba25 (or the BEC for that matter) don't have a USB port, you program them through the plug that goes into the receiver. That's why you need a little adapter between your USB cable and the unit. They call it the Phoenix Link.
crazy4wdracer
11.10.2007, 11:47 PM
what center diff oil should I run in my hot bodies lightning stadium Pro-R?
What about the front and rear?
squeeforever
squeeforever's Avatar
11.11.2007, 12:32 AM
10/30/5 is a decent starting spot.
