JThiessen
JThiessen's Avatar
11.12.2007, 08:24 PM
Yes, get a UBEC for anything 3s or more!
TBH, I think you'd be happier with lipos if you can swing it. I don't think I've seen any NiMH cells that can provide the current AND voltage BL systems can pull... not without stressing them anyway.
Dont forget, he said he has a $300 limit. I dont think you can get a full set up (motor/esc/UBEC/gears/heatsink) for under 300 unless you go with Novak. I'd also recommend a 4.5 instead of the 6.5. Its a little faster. IMHO, the Novak systems are great plug and play systems. No, your not going to be the fastest on the block, but they should be reliable systems that will hold up over the long run. 45MPH in a maxx is probably not going to happen, especially if you dont pop for lipo's. But you probably wont hit that with the systems mentioned above without lipo's either.
ClodMaxx
hold my beer... watch this...
ClodMaxx's Avatar
11.13.2007, 10:21 AM
diffs are the red headed stepchild of these trucks. it just seems strange that a stock diff is such an extremely weak link. i'm very interested to see how the new maxx diffs hold up to extreme power and abuse (i'll personally be torturing them with my LMT) that traxxas says they can take. i'm not holding my breath...
Eflite Blade 400 heli on 3s
Andrew32
11.13.2007, 11:47 AM
after LONG LONG intese thinking, i have decided to go with the MM and 8xl motor. going to run EP 4200 7cell for a while then ill take the dive into lipo after i pay my car off, only 6 months left
what gearing should i use. the gear calc says o use a 18 pinion and 66 spur to achieve 45. is that gearing to low? cuz ikbow he hv systems require like a 12pinion 72 spur.
11.13.2007, 09:22 PM
Not too low, maybe a little high infact. The 8xl will run a little hotter than the 9xl, so gearing down a touch is advisable- aim for more like 40mph; going faster than that will be hard to control. Easy way to know if you are over/under geared:
Hot motor + cool esc/batteries = under geared. (not enough load on motor, so it over revs)
Cool motor + hot esc/batteries = over geared. (too much load on esc to supply amps, causes it to heat up & thermal/fail)
Generally speaking anyway. You will want a fan on the MM and run a ubec to power the tx & servos (disable built in bec via programming or remove red wire from rx lead to esc).
Andrew32
11.14.2007, 11:35 AM
cool i guess gearing will just have to be a combo of the gearing calc and tem checking.
so i went to the CC part of the forum and people are saying NOT to run 14cells on the MM controllers cuz they are frying. Is this true?
mmdooley
mmdooley's Avatar
11.14.2007, 12:59 PM
Hey, I am running an 8xl with a quark, (But the MM should be fine) I assume you will be running a strobe with a 51 tooth spur? If so start your gearing at 14/51 and go up on the pinion to tweak it.
WE DON'T STOP PLAYING WHEN WE GET OLD. WE GET OLD WHEN WE STOP PLAYING.
11.14.2007, 07:03 PM
Well, the older MMs could do upto 14 cells/5s with no problems really. Newer MMs use different parts internally (fets) and the voltage limit has been lowered so that 12 cells/4s is the maximum. The Quark125b is a solid controller and good for more voltage, but sooner or later the heat spreader inside seperates from the fets, and it causes thermal shut downs, even though the outside of the case is cool (heat cannot travel between fets & case, so fets overheat). It is said to be the smoothest esc available at the moment though, which is a big plus for racing.
highflier
Emaxx- FLM wannabe
12.06.2007, 09:14 PM
Correction to above post 12 cells and 3s max lipos.
