2600 Kv rated motors? which one?
Revracer
Revracer's Avatar
2600 Kv rated motors? which one? - 01.06.2008, 09:13 PM
okay so i was looking at the Ammo 36-56-2600 for my race spec revo. tekno used a neu 1512/2d motor(2600Kv) and the mamba max controler, which is the same kv rating and esc that i was going to use. i was wondering if there was a nemesis or feigao XL motor with a 2600Kv rating(or similar 2500-2700). it will be run on 3s lipo and set up to race. cant afford the neu, or any motor that cost more than $120 so if someone could point to a feigao or similar motor that be great. thanks
jhautz
jhautz's Avatar
01.06.2008, 09:55 PM
http://cgi.ebay.com/Feigao-540-10L-B...QQcmdZViewItem
Here a Feigao 10L on ebay. 2458KV
You could also use a Feigao 7xl at 2382kv and gear it a tooth or 2 higher. The larger motor should allow the taller gearing no problem. Thats probably your best bet IMO.
http://www.rc-monster.com/proddetail...WAND_XL&cat=20
to make it...
or break it...
Silent...But Deadly
Revracer
Revracer's Avatar
01.06.2008, 10:04 PM
thats showin the 7XL is only 2145Kv. thats too low to run on 3s lipo isnt it?
jnev
jnev's Avatar
01.06.2008, 10:18 PM
Those specs have been wrong for a while now. The actual KV is what jhautz said: 2382
Revracer
Revracer's Avatar
01.06.2008, 10:20 PM
ok thats cool then. and i could gear that probly 18/36 instead of the 18/38 i planned and get about 35mph speeds like i would with the 2600 ammo? is there another motor out other than the neu that would get about 2600 Kv?
01.06.2008, 10:36 PM
if you can spare the dough ($210) check the 6xl motor out on this page.
http://finedesignrc.com/motorshacker.asp
if you can bore out your 5mm pinion to 6mm check this motor out.
https://www.unitedhobbies.com/UNITED...idProduct=4938
much more power than the feigao.
jhautz
jhautz's Avatar
01.06.2008, 10:57 PM
finedesingrc has a Nemisis 6xl also. Its a feaigo with a blue can.
to make it...
or break it...
Silent...But Deadly
squeeforever
squeeforever's Avatar
01.06.2008, 11:20 PM
Its not wrong...Its the loaded KV vs. the unloaded KV...
jhautz
jhautz's Avatar
01.06.2008, 11:26 PM
unloaded is what almost every manufacturer goes by except Lehner/BK so its the one that gives you the best comarison from brand to brand.
to make it...
or break it...
Silent...But Deadly
Revracer
Revracer's Avatar
01.06.2008, 11:29 PM
okay well like i said before i cant put much mroe than $150 into the motor. so a feigao 7xl or 6xl both on 18/36 gearing will give me about 35mph speeds and wheelies all over the place? thats what im looking for. enough torque to rip the wheels up, and fast enough to be a track truck on 3s lipo. and no i cant bore out the tekno electriclutch thingy. i dont want to try atleast. any other inexpensive but crazy powered motors out there?
squeeforever
01.06.2008, 11:33 PM
I would chose the Lehner XXL. There around $175 I think.
Revracer
Revracer's Avatar
01.06.2008, 11:35 PM
but will that fit on the tekno kit? i think the tekno kit cant take anythign more than like 78mm long or something...
jhautz
jhautz's Avatar
good luck finding one though.
to make it...
or break it...
Silent...But Deadly
Revracer
Revracer's Avatar
01.07.2008, 12:08 AM
will the feigao 6xl pull the wheels up easily on 3s with a 18/36 gearing?
jhautz
jhautz's Avatar
01.07.2008, 12:11 AM
I doubt anything will on 3s
If you want power go with 4s or more
to make it...
or break it...
Silent...But Deadly
