snellemin
2 KiloWatt RACER
snellemin's Avatar
02.20.2008, 01:42 PM
Aah yes, the controller alone is what I need mostly. Will there be a offering for the ESC alone in march?
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
Joe Ford
Castle's Chaos Corner
Joe Ford's Avatar
02.20.2008, 01:46 PM
We will be offering the ESC separately. The software that will be on the controller is the same as the software currently available for the Mamba Max (v1.17). Any motor that will run on it will run on a Monster.
Joe Ford
Product Specialist
lutach
lutach's Avatar
02.20.2008, 01:49 PM
Have you guys done any testing on heavier truck Joe?
Sower
Sower's Avatar
02.20.2008, 01:53 PM
Dang, looks like I might have to get another motor after all. I have a 6s NeuEnergy battery and I don't think the 2200kv motor will like that. Unless I like my motors to cook bacon and my truggy to go 80mph.
legobrains
02.20.2008, 02:18 PM
Why couldn't you just use the castle software and slow the motor down. but keep the volts?
Or couldn't you use some radio programing and set your end points down, and change your throttle expo (I have a nomadio sensor, but I think the spektrum can do the same thing.
Then you could keep your batteriers and motor, just not using their "full potential"
Sower
Sower's Avatar
02.20.2008, 04:47 PM
Well, that's the thing, for best efficiency I want to keep the motor in a certain RPM range. The 1500kv was the best for my calcs based on the gearing and 6s batt. We'll see though. The "gear down" idea sounds good, but I don't know that it will be what I'm after. Don't know that I could find a small enough pinion. 9t is the smallest I know of - maybe I could find a 4t.
ssspconcepts
ssspconcepts's Avatar
02.20.2008, 01:57 PM
Are we still good for March?
phatmonk
RC carbon junkie
phatmonk's Avatar
02.20.2008, 05:37 PM
What date will the mmm be available.I cant wait!
ssspconcepts
02.20.2008, 05:40 PM
It's down below in the thread @ 1:22pm:
"we are still shooting for March, but are presently waiting for things that are out of our hands. This obviously affects the release date."
Cain
02.20.2008, 01:56 PM
This should work out fine for me then as I already have my Neu motor, its a 1512 2.5D. I believe that is rated at 2000kv??
Any estimates on street price for just the ESC?
ravin
ravin's Avatar
02.20.2008, 02:15 PM
will it be at WRAM?
Joe Ford
Joe Ford's Avatar
02.20.2008, 02:22 PM
Ok...I'll try to answer this barrage of ?'s. Here goes.
lutach...we have tried this in up to 14lb vehicles. We are discussing a 1521 series motor for larger/heavier vehicles such as the LST2, etc.
Sower...gear down. ;)
Cain...no estimates on separate components at this time. That'll probably be figured out just prior to release.
ssspconcepts...we are still shooting for March, but are presently waiting for things that are out of our hands. This obviously affects the release date.
ravin...no, but I will be. :)
Joe Ford
Product Specialist
ravin
ravin's Avatar
02.20.2008, 02:44 PM
ravin...no, but I will be. :)[/QUOTE]
Good luck Joe ,snow is moving in for friday.
lutach
lutach's Avatar
02.20.2008, 03:20 PM
Joe,
Do you have data from the tests? Any reading from a DPR or Eagle Tree?
Sower
Sower's Avatar
02.21.2008, 12:01 AM
Well, by my calculations . . . if I had the 2200kv motor with a 10t pinion I would still have a 60 mph top speed and hit 50,000 rpms. So, what I've done is go out and buy a 1515 Neu 1100 kv motor. With a 15t pinion, that will be topped out at about 40 to 45 mph and 24,000 rpms.
I'll be getting the esc by itself now.
