othello
HV basher
03.21.2008, 04:54 PM
The Jazz 55-10-32 has no problems braking a Neu 1512 or neu 1515 on 10s1p A123 (comparable to 8s lipos). If i want to i can lock all wheels. when i do have to much grip the car will make a front flip when i'm too hard on the brakes. That's why i reduced brake to 95% on my remote.
11lbs truggy with Neu 1512 (1400kv): clip1, clip2, clip3
Same Truggy with Neu 1515/2Y (1100kv): clip1, clip2
The Jazz ESC is able of peak Amps above 120A eventhough it's only speced for bursts up to 65A.
aqwut
Brushless Heavy Weight....
aqwut's Avatar
03.21.2008, 06:37 PM
I have 2 MGM24.160 and the brakes are just way too strong... even on the lowest settings... if you throttle lower than the current RPM, it will slow the motor right down... I need a firmware update, but don't want to send it to MGM... if you have the new firmware.. then it would be great...
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
jzemaxx
03.21.2008, 07:24 PM
Do you want to sell one ?....lol
aqwut
aqwut's Avatar
03.21.2008, 09:08 PM
I would if I wasn't putting dual brushless into my GST.. :) the 40.160WK is the smoothest ESC I've ever used...
jzemaxx
Hmm sounds like I am better sticking to another HV110 and just thottle it down....especially since a Neu pulls down a truck quick once you let off. Also looks like MGM's are not the ticket either....
aqwut
aqwut's Avatar
03.21.2008, 09:12 PM
or The cheap HobbyCity Turnigy Sentilon 12S 100A ESC... $100 and I'm really digging those ESCs....
jzemaxx
03.21.2008, 09:30 PM
You know anybody that has tried one of the Turnigy's??? How does it compare to the HV110??? I'm looking to buy one this week.....
aqwut
aqwut's Avatar
03.21.2008, 09:38 PM
I have about 10 of them... I love them... They have constant of 100A... but on 12S, that's enough juice... I'm ordering 6 more tonight.... Each ESC can output 4440Watts of continuous power... for $100 that's is Just plane awesome... I've used this with one of my Savages and 7XL and 4S... works great.. only thing is.. you'll have to use mechanical brakes... which I don't mind...
jzemaxx
03.21.2008, 09:40 PM
Hmm how do they do with heat...does a heatsink need to be added? One thing I forgot though is will it work with a 4 pol motor though?
aqwut
aqwut's Avatar
03.21.2008, 09:44 PM
They work with 2, 4, 6+ pole motors... there is a heatsink installed.... just add a small fan for extra cooling... it's great...
The only thing I recommend doing is siliconing the Capacitors together.. or shoeGoo... they need to be secured better...
jzemaxx
03.21.2008, 09:45 PM
I wish my emaxx had mech. brakes......guess I'll just have to play with the throttle to slow the truck down on high speed passes.
jzemaxx
03.21.2008, 09:46 PM
What are you doing for programming it? Did you buy the programming card?
aqwut
aqwut's Avatar
03.21.2008, 10:59 PM
yup.. I used the program card.. it's easy to do...
I just ordered 6 more ESCs....
03.27.2008, 01:17 AM
Do you like to have spares, or have you got 6 vehicles to convert? Starting to sound like me, too many projects!
aqwut
aqwut's Avatar
03.27.2008, 01:38 PM
Am I allowed to choose both.. I like to have a few spares, and I have a few to convert.. I was going to make quad brushless firehammer MT for when I go to the WFRCCC Event, but since I'm not going, I will just make it a dual brushless.. so I'll have 2 Spares..
2 more for the CEN GST and Neu 1527/2.5D, instead of 2x 24.160... I always wondered how would the cheap Hong Kong esc work for the NeuMotors.....
sorry for being off topic...
but I really like those ESCs....
** To get rid of the delay, just set the throttle trim forward to your desired position.. Mine's at 40% Forward, so there's hardly any delay.
