TDC57
TDC57's Avatar
05.08.2008, 06:56 PM
Originally Posted by Fast5sRevo88 View Post
Hey TDC, did u have to do anything special to get that waterproof reciever box attached to the FLM emaxx chassis?
If your planning on using the duel steering servos then you will need to cutoff the end of the 3905 rx box (IE) the part that holds down the wires going into the box.
If you plan on using a single steering servo then no issues (piece of cake) it wont be centered like it is shown but it provide you with a full water protection and (heck) a little offset never hearts anything.
Hope that helps..
Have a great one.
Nothing!.. Hahahahaaa..
Fast5sRevo88
05.08.2008, 08:57 PM
That's great, i will be using a single servo setup. I knew my JR 320oz/in digital servo was good for something!
TDC57
TDC57's Avatar
05.09.2008, 04:14 AM
OOOo yah.. No worries at all Fast5sRevo88..
You’re going to love the JR servo.. I’ve always had great success with mine. I’ve got the JR DS8711 in both of my builds.. I just love the 400 oz of torque it provides.. I stripped my anodized off for my GEVO
But left it on my G3
Post some pics of you bad boy when you have the time..
Have a great one..
TDC57
TDC57's Avatar
05.11.2008, 12:54 AM
OOOoooo.. it would help if had known that’s what you meant (me bad)..
First you will need the FLM 10600 trany adapter on the transmission and review your placement options. Two options are available (front or rear), I chose the rear so wouldn’t encroach on the front servo plate.
Then you should run a screw on both side of the transmission through the frame rails. These screw will work on the back front hole. (IE) the transmission holes are (4) total on each side and they are broken up in sets of two with the divider in the middle so the only original screw hole that will work in the back set / front hole.
Then you will need to enlarge two of the existing holes per chasis rail, I ran mine in rear back and front back holes. The front / front hole doesn’t work with the transmission adapter on each side of the frame rails, I found that the dermal works best for this. (you do know that you can only use a total of (6) screws?)
GO SLOW and for god sakes man!! don’t drink or (whatever) before attempting this rail fabrication!! But one you successfully completed this fabrication then by all means feel free to indulge in the finest brain cell killers money (and the law “wink, wink” will allow..
You will also need buy longer transmission screws and washers for them… the screw size is 20-25mmL (I think??) your call..
That about it (simple haaaa)
Hope that helps??
Have a great one..
TDC57
TDC57's Avatar
05.20.2008, 01:22 AM
So how is your conversion coming Fast5sREVO88?? Any updates for the team??.
Thanks for your time and have a great one..
Fast5sRevo88
05.20.2008, 12:15 PM
Well, that conversion got side-lined for now, at the race the other night my G3Revo blew a diff or so i thought, it turned out the center front shaft came loose, it was dark at the race so i couldn't see that the pin was missing, anyway, i also broke a rear plastic shaft on it, so i'm having to do an emergency CVD-section. My stepdad also wants to start racing after he saw the race; first timer, so i have to get my X1-CRT BL-ed and ready to race so that he can run the Revo
Switch.
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Switch. - 05.20.2008, 12:24 PM
Wow thats a switch. It is usually the fathers trying to get their kids into the hobby, and here you are helping your stepdad acquire the addiction. He does know that it is an addiction right? There is no 12 step program to help kick the habbit either. Once your in there goes your extra play money and maybe even some of your bill money. What a great way to bond with your family though, but to get the whole family involved in BL racing. Way to go Revo88.
Fast5sRevo88
05.22.2008, 07:37 PM
Yea Jerry, its a switch. Up until the race he didn't understand why i spent so much time working on my trucks. TDC, u can use the center driveshafts, but was u able to use the traxxas outer drive steel CVDs?
TDC57
TDC57's Avatar
05.23.2008, 04:13 AM
Hay Fast5Revo88
Yes I was able to use the stell CVD drive shafts, the part number is (#5451R)
Have a great one..
P.s.
I'll be snipping your GR3 in 4 days..
TDC57
TDC57's Avatar
05.23.2008, 07:07 PM
HHHHhhhaaaaa thats a good one...
Have a great weekend Fast5sRevo88..
ps.
(good luck on your race next week).. is your step dad racing too?.
Fast5sRevo88
05.23.2008, 07:50 PM
ps.
I'm afraid not this time, I'm going to let him practice with my mini Raminator before i hand over one of my million-dollar trucks.
Buzzsaw46
05.24.2008, 10:53 AM
Hey guys, would this adaptor plate work with my FLM EXT-maxx chassis? I would love to convert the T but dont want to spend a fortune on it! $17 for the adaptor and a 3905 tranny would be well within budget!
Fast5sRevo88
05.24.2008, 12:47 PM
This adaptor was actually specifically designed for the FLM chassis.
Buzzsaw46
05.24.2008, 05:24 PM
I know it was made for the FLM E-Maxx chassis I was wondering if it would work with the EXT .21 nitro chassis, so I dont have to spend the $90 on an E chassis. From what I can see though it should work.
TDC57
TDC57's Avatar
05.25.2008, 01:37 AM
Hay Buzzsaw (If that it your real name?) HHhaaaa hhaaa sorry I’m in a mood.. I would call or email Mike AKA the MONSTER! and ask him??. I wish I knew the answer but I don’t..
Sorry and have a great one..
Shaun.
