kulangflow
Never Fast Enough
kulangflow's Avatar
05.13.2008, 12:40 AM
Originally Posted by RBMike View Post
Sorry for the off topic but could you please tell me your whole set-up & run time? car,Motor,gearing. I just finished an MBX5 conversion & am using A123-6s. Plan on testing later tonight.
3905 E-maxx - 9XL - 24/68
I only ran it for 15 minutes before I twisted a drive-shaft. I haven't had time to fix that yet so it sits for now.
Sparky
Sparky's Avatar
05.11.2008, 04:56 PM
Good! I'm glad to hear that. I hope these few problumes are was just flukes.
DickyT
05.12.2008, 10:29 AM
New MMM on the way! Castle is the best, 1st round quirks aside ;)
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
05.12.2008, 06:17 PM
That is great news
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
DickyT
05.12.2008, 01:14 PM
failed bec.
finfin
05.12.2008, 10:23 PM
failed bec.
what is the solution for this problem?
Have any solution from CC yet? Please CC....
DickyT
05.13.2008, 06:57 AM
They are sending me a new one. Patrick said in another thread that they have not received any back yet for post mortem diagnostics. I'll get mine to the as soon as I have the shipping materials.
05.12.2008, 01:29 PM
Does it work it you leave the red wire in and use an Ubec. Can you reverse power the brain board I wonder....
DickyT
05.12.2008, 01:50 PM
No, i did not try ubec, was not soldering just to test, but pulled red wire and tried rx pack I had on hand. only got steering.
and it decided to castle link again, i reinstalled the drivers on my pc. but still will not power on, and the fan just twitches when you flip the power switch.
05.12.2008, 01:59 PM
What happen if you lead the red wire in - Ie power ESC from rc pack...
skellyo
skellyo's Avatar
05.12.2008, 02:15 PM
I wouldn't try that if it were me. With doing so, he'd be backfeeding voltage across the BEC circuit that has already failed and he measured to be 1.47V at the output. There's some sort of low impedance shunt in that circuit and applying an external Rx pack will apply 5V directly across that low impedance. I'd bet that there will be some smoke as a result.
JerryF504
I don't understand, but I don't think I like it.
JerryF504's Avatar
05.12.2008, 02:21 PM
I say let it smoke.
JerryF504
JerryF504's Avatar
05.12.2008, 02:20 PM
Well, I just had the same problem. After the first 5 min of running my bec went to 1.09 volts. I came in and tried a receiver pack and everything runs fine off of it. My setup is a 9xl on 6s in a 3905.
skellyo
skellyo's Avatar
05.12.2008, 02:28 PM
Wow, I'm surprised. I'm curious as to how much current the Rx pack is having to provide in this instance. Does the Castle Link work on yours without having to power the ESC with a Rx pack?
JerryF504
JerryF504's Avatar
05.12.2008, 02:55 PM
Nope, cl doesn't even see that it is connected to the computer. The weird thing is after I connected the receiver pack I disconnected it to put a Castle bec in its place and tried it again and it worked normally for a few minutes then flaked out again.
