Originally Posted by Duster_360
If you have no other way and need precise vertical hole, dremel make s drill press attachment.
http://www.dremel.com/en-us/Attachme...spx?pid=220-01
I have one (gift from inlaws) and a real drill press which is what always gets used for holes. I also use the AC verison of the dremel.
He already has that...
You'll be fine drilling with the dremel, and better off if you can use that press attachement. I've been considering one of those... Carbide tipped bits are definately the way to go, and just take it slow.
J.
