05.16.2008, 04:17 PM
I only asked for a price of the 5mm shafted rotor for the C50-maxx motor and that's what he gave. I did swap the rotor fro my 13L into the C50-maxx and they fit like a glove. So when you guys e-mail or call Kyle ask for the C50-L rotor and not the C50-maxx rotor.
When you swaped the l length shaft/rotor in what kv did you end up with? Was it similar to the 13l, they output wires look to be the same diameter.
I have a 13l, 14l, and an 8l, and the 8l has much thicker wires coming out of it.
Takedown
WARNING: May become violent.
Takedown's Avatar
05.16.2008, 02:39 PM
Found the upgrade- http://www.impaktrc.com/product_info...osCsid=d5e22ae
The rotor looks tiny for the size of the motor...
RIP- Tammy (9/14/08)
brushlessboy16
brushlessboy16's Avatar
05.16.2008, 03:07 PM
How much do hackers run with the 5mm NIB?
Takedown
Takedown's Avatar
05.16.2008, 04:21 PM
Thanks a bunch lutach. Thats the first upgrade I plan to get for sure when I get the hacker.
lutach
lutach's Avatar
05.16.2008, 04:26 PM
It's a must if you don't want to snap your shaft.
05.16.2008, 04:33 PM
And snapping your shaft sounds very painful!
lutach
lutach's Avatar
05.16.2008, 04:39 PM
Did lincpimp steal you username and password . You guys crack me up . Palmela Handerson
Takedown
Takedown's Avatar
05.16.2008, 04:55 PM
One more question... Ive heard that the feigao L series rotors will fit into the hacker c50 motors. Is this true?
lutach
lutach's Avatar
05.16.2008, 05:03 PM
Even if it does, I wouldn't do it. The C50 rotors are wrapped with Kevlar and the magnet is different as well. Maybe that's why the Hacker C50s are more efficient.
Takedown
Takedown's Avatar
05.16.2008, 05:05 PM
Hmmmm... Good point! I will keep an eye on the hacker 5mm upgraded rotor as well.
05.20.2008, 12:21 PM
Got an email reply, here it is:
James,
Yes we do sell a rotor that is 5mm in size for the C50 Maxx motor. The C50 L rotor will not work with the C50 Maxx motor for it has a special magnet length.
The 5MM rotor would be $75
Best Regards,
Kyle Bergstrom
Aero-Model/Hackerbrushless USA
Repair Dept. Manager
www.hackerbrushless.com
www.Aero-Model.com
2122 W. 5TH PL.
Tempe AZ 85281
lutach
lutach's Avatar
05.20.2008, 03:42 PM
James,
Best Regards,
Kyle Bergstrom
www.Aero-Model.com
2122 W. 5TH PL.
Tempe AZ 85281
Wow. I should reply to Kyle now and see if he still can do his $50 for the rotors . Good thing I save most of my e-mails . Might be because I was going to buy 2.
05.20.2008, 06:20 PM
Worth a try...maybe he will give them to you for 50 each if you buy 2. I would buy one for 50 or so, see what he will do for you if you buy 3! Was the 50 quote for the stock replacement, or the 5mm version?
lutach
lutach's Avatar
05.21.2008, 12:28 AM
I'll send Kyle an e-mail tomorrow and I'll let you know what he says.
killajb
killajb's Avatar
05.20.2008, 09:09 PM
This is just an observation.. but a $50.00 motor which will require a $50.00 upgrade and will STILL be a very high kv wind if used.. Doesn't it make more sense to just opt for a Medusa Afterburner instead?
