cemetery gates
07.19.2008, 04:35 PM
Alright guys, the crt.5 is up and running! Well somewhat; all I had to put in it was a mm5700 with a 12t pinion(on 2s). I think it'll get a little hot, but it should be ok for a 10min race. If anyone has a smaller pinion that they can bring that I could possibly borrow for the race I would appreciate it!
I'm bringing the following vehicles:
Full size Jammin Crt
Jammin Crt.5ext (with matching paint job too)
Bye
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
07.19.2008, 08:02 PM
what's the date for the annual bash? If I hadn't done my CRT.5 build in less than 2 weeks I would have had the money to come tomorrow. But I also would have only had a stock E-REVO to bring. Very glad I did the build thoughcsuse it's awesome. I will be posting pics when I get my computer back
cemetery gates
07.19.2008, 09:14 PM
I'm really pissed now. It doesn't look like I can go. My car had a dead battery earlier today, so I charged it, drove around for a couple hours(had to go to some stores), it seemed fine. I go to start my car tonight, it's dead again. I just charged it again then left it idling for an hour. It measures 14.8-15.0 volts. Is that normal? It's just I'd rather not get stuck over an hour from home with a dead battery. Then again, I could roll it down a hill and pop the clutch to start it...
Fix It.
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Fix It. - 07.19.2008, 09:23 PM
Just pop into the local "AutoZone" and ask them to put it on the tester(its free). They will put you in the right direction quick and you will be on your way. It sounds as if you have a bad battery since your system is putting out the voltage. Get the car running and disconnect the battery. If the car dies, then you have a bad alternator. If the car keeps running, then your battery is bad. Good luck with that.
cemetery gates
07.19.2008, 09:35 PM
I'll have to bring it there at 8am tomorrow because it closes in like 25min and by the time I get there it'll be closed. Huh...
07.19.2008, 10:53 PM
Just get it going and bring some jump leads... Start it off a 3s lipo :)
cemetery gates
07.19.2008, 11:05 PM
I cant promise anything. I'll try to make it, It's looking like I really cant though, sorry. I could do next week if you all are up for it.
Bye
07.19.2008, 11:23 PM
I'll be there next week to...
cemetery gates
07.19.2008, 11:26 PM
Great! Then so will I!
Running???
JERRY2KONE
JERRY2KONE's Avatar
Running??? - 07.20.2008, 01:28 PM
Well did you get your car running? Did you figure out what the problem is yet?
cemetery gates
07.20.2008, 03:14 PM
It was the battery. I got a new one and it seems fine now!
Bye
07.20.2008, 07:12 PM
FYI -Barn closed next weekend but was thinking about hitting here:
http://www.dirtrunners.com/main.html
lutach
lutach's Avatar
07.20.2008, 08:19 PM
I might hit Dirt Runners to test the new ESCs. It's only 40-50 minutes away from me.
cemetery gates
07.20.2008, 09:44 PM
Where is that track exactly? Is there any other tracks close? How did the racing go today? Who showed up?
Bye
brushlessboy16
brushlessboy16's Avatar
07.20.2008, 08:33 PM
so was there an NJ bash?
