mickeymoose
08.01.2008, 10:06 PM
Hi I made it myself, I'm running mod1 gears 9XL with 18t pinion and 52t spur, I'm using an MGT spur/slipper, it's exactly like an E-Maxx slipper only mod1.
lind5
08.02.2008, 04:42 AM
ok mate well good job done on making it your self look great
thanks for the pm and if you do ever make any more bear me in mind its better than i could ever do
TexasSP
Something, anything, nothing
TexasSP's Avatar
08.02.2008, 03:34 PM
If you have the chassis designed on cad you could at least sell the file, I am sure many would pay for it. Or even better, make them yourself and sell them. I think basing it off the 3905 tranny would be best.
Again, it is a very impressive conversion to say the least.
www.cubicle101.com
mickeymoose
08.02.2008, 09:36 PM
Thanks for all the good words guys. The truck does work extremly well though, I personally think it's a better option than a Revo IMHO. I think you guys are convincing me to produce some of these, but make no mistake it is very time consuming pursuing things like this. I looked at the 3905 tranny, but I'm pretty sure it would not work for this application because the motor mount flares out right at the bottom of the tranny and it looked to me like it would interfere with the battery tray mount location. Thanks again for the compliments.
lind5
Arrow 08.03.2008, 07:44 AM
hopefully your get them into production soon
i got my mgt rr slipper and spur turning up soon 54 tooth
i have also been told that the lst 2 speed 2nd gear will fit the rr slipper hub. not sure how it would effect the gearing as this seems to be a fair bit bigger 60+ teeth
how would effect the temps of the motor esc and batterys as i am going to be useing the old emaxx transmision on the lst chassis
pinions i have to use are the 16/17/18/and 20 tooth
lind5
08.04.2008, 11:59 AM
hi got a second hand emax chassis today so im gonna try mount that onto the top deck of the lst that should give me a base to put the emax transmision and some where to mount the lipos
at least i will be able get it together and then see about getting some kind of alloy chassis made made up to replace stock one whilst weighting for my mamba monster 2200 kv combo
Geogenesis13
RC-Monster Ruthenium
Geogenesis13's Avatar
08.05.2008, 01:13 AM
lind5 why aren't you impressed with the revo
"Its a bird."Its a plane.""It is my E-Revo and bl 5T you idiots."
lind5
08.05.2008, 05:11 AM
hi mate well i built it from scratch everything was new i didnt use a donner car
gmaxx chassis
gmaxx single speed
gmaxx single motor mount
emaxx gearbox
complete metal gears
quark monster pro esc (now cooked)
1515 1.5 motor
3 racing alloy diff cups
3 racing alloy bumpers
integy alloy tie bars
integy alloy skid plates
traxxas cvds (snapped x2)
traxxas red alloy tie rods (snapped x2)
traxxas red alloy steering arms (snapped x1)
traxxas hard anodised pivot balls
rpm wishbones
rpm hubs (piviot ball pulled out x2)
titanium hinge pins
proline 23mm wheel hex (inner pins snapped x?)
proline 23mm 40 series wheels
proline 40 series max mulchers
proline single steering arm
i think thats about
well any way it seems every time i took it out some thing broke on it
and when you have spent this much hard ernt cash it just p****s me off
but i can beat the crap out of my lst and it just keeps going so that is why im now wanting to convert this one
TexasSP
TexasSP's Avatar
08.05.2008, 01:14 PM
You had a lot of weight on that revo with all the aluminum. That was probably a lot of your issue with breakage. When that much weight moves around at high speed in a truck that size, carnage gets worse. I went through this with my first to maxxes. Adding aluminum everywhere and trying to make it bullet proof, but the more I put on the more problems I had. My 3905 maxx is basically stock except for the BL system and radio and I don't have hardly any problems. If I break a part I replace it with a stock part and go on.
www.cubicle101.com
lind5
08.05.2008, 03:47 PM
but thats my problem i always have added alloy parts on all my cars
i just like shiny bits
i guess i will have to try and hold off with the lst although its all ready got a couple of bits on
decided to try making my own chassis plate today its getting there looks quite good
although it is alot like mickeymoose's chassis
i just took the emaxx chassis and placed it over the std lst chassis and drew around them ..
i will try to post some pictures soon
TexasSP
TexasSP's Avatar
08.05.2008, 05:30 PM
It's hard, they do look pretty. I have just been through it several times and try to stay stock unless it's a forced upgrade.
www.cubicle101.com
lind5
08.07.2008, 08:00 AM
ok well this is about as far as i can get without the esc hope you guys like it
lonbhold75
08.07.2008, 08:34 AM
Looking good lind5, can't wait for the test runs
lind5
08.07.2008, 08:54 AM
yeah im hoping it will be better than the revo conversion
one of them spare mamba max's you have wouldnt go a miss
i could try it with my 7xl on 4s
just to see how it runs
but you no me i do tend to cook esc
bdebde
That's All Folks!
bdebde's Avatar
08.07.2008, 09:22 AM
Looks like the rear suspension is on backwards.
