starscream
RC-Monster TQ
starscream's Avatar
08.06.2008, 04:44 AM
I have Apogee packs and have never balanced them even after 25 runs.
I posted this quote, from Apogee's site, before but I'll share it again:
"For years we have sat quietly aside watching the proponents of "pack balancing" spew forth misinformation. The truth is that a properly matched pack will not require balancing. Yes, we're sure this is a shock to many of you who have fallen for the balancing gimmick. Yes, Apogee was the first to put commercial grade plugs on all packs due to customer demand. We've had and seen enough.
Pack balancing is a gimmick perpetuated by companies who make balancers, and by other companies who do not match battery cells within the pack. A properly matched pack will not require balancing, and in fact will mask a failing cell. Balancing is a band aid for companies who lack the proper equipment to do cell matching. All Apogee packs have been cell matched since the day we started.
Due to misinformation, more packs have been damaged during balancing than have been helped. If you insist on balancing a pack (If it makes you feel warm and fuzzy inside, and you sleep better at night, have at it), please, please, only balance fully charged packs.
Why only balance fully charged packs? All properly matched cells are mated together so that the high and low voltages will coincide. There may be mid-point voltage variances. Balancing a partially charged pack can cause the high and low voltages to become unbalanced. Again, please, if you insist on the balancing gimmick, please only balance fully charged packs."
Ha Ha
tc3_racer_001
tc3_racer_001's Avatar
08.06.2008, 05:10 AM
i still dont agree. id rather slowly damage my pack than have no house.
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
bruce750i
bruce750i's Avatar
08.06.2008, 10:08 AM
I can see where apogee is coming from. I don't balance every time. I think it depends on how many cells that are in the pack. I did see a new esc somewhere that plugged into the balancing plug to use all the cells voltage appropriately or something.
ffactory666
08.06.2008, 07:26 PM
How can Apogee say you never have to balance , doesn't make sense .
I know myself when checking the batteries sometimes they are slightly out of balance and on the rare occasion when not run for a while are more out of balance .
Isn't what they are saying dangerous ?
08.06.2008, 09:57 AM
I hook up my packs to the balancer before I start the charge. If they are really close to being balanced, I start the charge. If they are a little off, I wait until they are really close before starting to charge. Either way, I balance everytime.
jayjay283
jayjay283's Avatar
08.06.2008, 11:06 PM
I thought cell phone batterys were lithium manganese and 3.6v max.. Apogee seem to be 4.2v peak. Strange they dont make anything higher than a 3s and 20c max. Doesnt say anything about weight. How heavy is one of your packs relatively ?
starscream
RC-Monster TQ
starscream's Avatar
08.07.2008, 05:07 AM
I'm not positive about cell phone batts but I think they are Lithium Ion cells like Laptops. Laptops and cell phones can get away with using lower C capacity cells because they do not require the const current a vehicle does.
As far as the Apogee packs available, it depends on what mAh Apogee packs you're looking at. The 5800 mAh are only available up to 3S but the 2200 mAh and 3800 mAh are both available up to 6S.
I run 2x 4S 2200mAh in series or parrallel depending on the vehicle and each pack weighs approx 8oz.
I may run 6S2P 2200mAh in my 8th scale whenever the MMM shows up.
Ha Ha
azjc
08.07.2008, 11:27 AM
I run FP packs exclusivly and I use a Hyperion 0610i charger with a builtin balancer so it is no extra effort to balance while charging, but I have tried charging and not balancing for about 3 charges and than tried to balance and only minimal discharging was needed
jayjay283
jayjay283's Avatar
08.07.2008, 02:59 PM
I use the 610iDuo and charge and balance my collection of Neu 30c 5ah packs each time. Never tried it not balancing. Never tried just balancing after charging. I just stick with whats working lol... those apogee are interesting ! Sound like a safer lipo. Maybe ill try a couple for my nephews who want to get into RC more. As it stands I have to charge/balance, hook it up in the car, turn it on etc. New stuff that makes it easier would be nice to feel better about letting them do it on their own. These kids are complete nintendo generation mindset. I had them mow the back yard and the mowed my hose, an extension cord and eventually the pull cord to the mower. No common sense lol Some apogee with a built in LVC like the trinity lipro's would be a real nice option.
hoober
08.07.2008, 07:43 PM
Apogee is spot on for normal use. Even packs that are not very well matched will be in balance when ful if they started out that way.
I won't say that I never balance, but do check my packs at least once or twice a year. If they need it then they get it.
The nice thing about balancing every time is that it desn't hurt anything.
08.07.2008, 10:46 PM
Originally Posted by hoober View Post
...The nice thing about balancing every time is that it desn't hurt anything.
Exactly!
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
08.14.2008, 09:49 PM
what is the range to be considered in balance? Example, within 0.0-0.1 volt difference, 0.0-0.05, or 0.0-0.01 between cells?
Also if using a voltmeter to varify the voltage readings on the cells would I touch the red voltmeter probe to the red balance wire and black to each of the black ones?
08.14.2008, 10:03 PM
I'd shoot for 0.01-0.05v between cells. 0.1v is too much.
To measure each cell:
Cell 1-Red probe to red wire and black probe to 1st black wire next to the red one.
Cell 2-Red probe to 1st black wire next to the red one and black probe to 2nd black wire.
Cell 3-Red proble to 2nd blac wire and black probe to 3rd black wire.
And so on...
