snellemin
2 KiloWatt RACER
snellemin's Avatar
09.16.2008, 04:24 PM
If you can get the 6s capable feature to work on the 200A one, you will have another buyer. Could you pm me the est. price?
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
lutach
lutach's Avatar
09.16.2008, 04:30 PM
I'm not 100% sure if this units can handle 6S though. I'll have to actually get another test unit to see if it does. This are meant for 1/10 scale and as we can see, 2S lipos seems to be the standard for racing and this were meant for racing. I'm not going to get prices for the 200A yet as I need to test it. I did find a little problem with reverse that needs to be addressed, but everything else works like it should. I have the 200A ESC set for forward/brake only now.
lutach
lutach's Avatar
09.18.2008, 03:55 PM
Here is a video of the 200A ESC in action. I'm using my old Kyosho KX-One and it's geared for torque so it's not fast at all plus my rear diff is slipping a bit.
tom255
tom255's Avatar
10.11.2008, 02:43 PM
Hi Lutach
I found and bought on ebay with exaclty same footprint ESC but different brand than SP or Feigao. And its rated 100A. Is it support 4S lipo with UBEC? Did you tried it on 4S?
lutach
lutach's Avatar
10.11.2008, 04:44 PM
Originally Posted by tom255 View Post
Hi Lutach
I will try 4S soon with my drag car. You have to disable the BEC to run 4S. Did yours come with the program card or you had to buy it separately? I know one other guys from Spain that bought one, but the company sold him the wrong program card and they didn't offer the program card that is supposed to work with the ESC.
stum
10.11.2008, 11:04 PM
I'm about to buy a MM w/ BEC unless someone can hook me up with directions to one of these truck esc's. 120-200a would be nice... this is for my soon to be completed Losi 8ight-T tekno conversion. I'm running a neu 1515 1.5d in it... 4s lipo config
lutach
lutach's Avatar
10.12.2008, 10:41 AM
The above mentioned ESCs are for 1/10 scale and not for 1/8 scale. The software that they have is best suited for 2 pole motors unless some manufactures are willing to do a 4 pole motor with sensors.
10.12.2008, 12:20 PM
I might get one. After my HV Hyper ST is done, It looks like I'm getting bl-is-future's Hyper 7. I found a great deal on a 8xl, and will run on 4s. Your 120a ESC looks like it'll work well for my needs.
lutach
lutach's Avatar
10.12.2008, 12:22 PM
My 1/10 ESCs will work fine with the Novak HV motors. I will try the 200A with 4S lipos to see how it does and I'll post something here.
10.12.2008, 12:25 PM
I'm not a novak fan. Not a fan of novak's fans or novak's fan club for their fans.
e-mike
e-mike's Avatar
10.12.2008, 02:58 PM
I will try the 200A .
what is the brand of this esc?????im looking for one...but i dont know where i could buy one unit...
D8t on juice!!
tom255
tom255's Avatar
10.13.2008, 04:10 AM
Lutach
Did you tried run your Sensored/Sensorles ESC with 4 pole motor, Its interesting how it runs... I have MedUSA motor and think to use ESC with that motor.
And second question about Ez-Run Line ESC's, do you know how Arthur will mod your 60amp ESC? Improove cooling and some caps or he will stack to parralel two FET boards?
I have 60amp Ez-Run ESC too, but afraid to use it on buggy conversion yet. If he stack fet boards maybe I will do same, buy one Ez-Rune ESC additionaly. But wants to see how he do that...
lutach
lutach's Avatar
10.13.2008, 09:14 AM
Lutach
I did a bench test, but it was with the first 100A unit that I was having trouble with the software. It spun my Neu and my 6 pole motor. I couldn't do a road test because I don't have anything with a higher Kv at the moment.
He'll improve cooling. I asked him if we could add anoter FET boards and he said it wouldn't be needed.
One of my driver used the 60A in his ZX5 with out any issues (it's 1/10th scale though and the 60A might not have the grunt to run the 1/8 scale conversions), but he used the motr that came with the system. All I know is that the eZRun line can drive 4 and 6 pole motors with no problem. Just make sure you set the right timing. I'm running the 35A version in my Recoil with my own 4 pole 6000Kv motor, but the motor is only 24mm in diameter. I ran the 60A with my Mega ACn16/15/1 (9200Kv) and it was fantastic. I'm also going to try the eZRun 35A with my own 7500 and 9000Kv 4 pole motor.
tom255
tom255's Avatar
10.13.2008, 09:31 AM
I have tested Ezrun 60A esc too on 4S with UBEC and with my 4Pole MedUSA Motor, and it ran fine on my HPI Sprint 2, smooth and powerful. But Not tested yet on 1/8 buggy. Maybe I will do that soon.
lutach
lutach's Avatar
10.13.2008, 09:45 AM
That would probably be too much for the little guy. The way I treat my ESC is this. If it rates it for 60A, I try to get a burst or spike of 60A only and after the vehicle gets rolling, I won't see those spike anyways. A lot of people think most ESC can do their rated current continuous, but they really can't specially when they are not designed by a Thermal Engineer. The 200A sensored ESC or example have gone to 178A and that's only spikes.
