10.25.2008, 03:54 PM
Originally Posted by bustitup View Post
hint hint
It's not listed under Ofna because the ones there are "specialty". At the top, right under Miscellaneous, is the 46T spur.
BlackedOutREVO
10.25.2008, 02:15 PM
The spur is 46 yes
The 9L runs pretty nice. Has good power, runs pretty darn cool also.
But if you can swing that Neu, DO IT!
And 4 in is std 2.2 truck dia, so 3.5 is buggy. Depends on what he is running
Snipin_Willy
Snipin_Willy's Avatar
10.25.2008, 08:35 PM
I already posted on your thread but a 1509 will keep the front wheels off the ground running 2.2 gladiators. 1512 should be a bit snappy!
MetalMan
MetalMan's Avatar
10.26.2008, 01:43 AM
The 9L on 3s is a great motor in a CRT.5, especially with an 18t pinion and 2.2 truck tires. My MM and motor never exceeded 150 deg. F in that truck, despite the 45mph top speed. Can you say power!
entjoles
10.26.2008, 10:08 AM
i ran a 9L (thanks BrianG for the suggestion) in my crt.5 with 30 series proline bowties and 14/46 , ran @ 135* and had plenty of power
3s
to bad i sold it , it is a very fun truck
bustitup
10.26.2008, 11:30 AM
Originally Posted by entjoles View Post
i ran a 9L (thanks BrianG for the suggestion) in my crt.5 with 30 series proline bowties and 14/16 , ran @ 135* and had plenty of power
14/16?...did you mean 14/46?
david lamontagn
10.26.2008, 11:39 AM
Probably, he
entjoles
10.26.2008, 11:43 AM
yeah 14/46
i think i should go back to bed
bustitup
10.26.2008, 11:53 AM
yeah 14/46
any pictures of this rig?...crt .5 with 30 series
entjoles
10.26.2008, 12:12 PM
bustitup
10.26.2008, 12:19 PM
those 30's look awesome.....what hex and what mount are they?...would I need adaptors?
david lamontagn
10.26.2008, 12:22 PM
If i,am right, the crt.5 stock hex is 12mm, same as Traxxas rustler, and i suppose that entjoles have use the proline nitro rustler rear wheel at four corner
No i just take a close look at the pics and entjoles use the proline traxxas adapter for nitro rustler and universal wabash 30 serie proline wheel......
THis one:
http://www3.towerhobbies.com/cgi-bin...?&I=LXMUG0&P=7
But entjoles correct me if i am wrong, but you need two set of this adaptor because you need 4 rear one and the kit comes with 2 front and 2 rear, right?
And this wheel:
http://www3.towerhobbies.com/cgi-bin...?&I=LXMUF7&P=7
entjoles
10.26.2008, 12:41 PM
THis one:
And this wheel:
yup
david lamontagn
10.26.2008, 02:12 PM
I will put exactly this setup on my crt.5. But i don,t have the RCM extended one, but i,ve the new crt.5 pro with the extended chassis, but i think that this chassis is shorter than the RCM one. Hope that this 30 serie wheel will not look too bad on it
