spaz163
Functionality with a dash of Form
spaz163's Avatar
03.12.2009, 01:23 PM
Don't forget about the Team Losi 8ight E battery trays as an option. They are very cheap!!
Tray
Straps for the tray
whitrzac
Can't catch this...
whitrzac's Avatar
03.12.2009, 01:42 PM
Tray
Straps for the tray
I have the novak trys on the way here...
if I pick up a 9t pinion do you think it will be fine untill I can get a diffrent motor??
03.12.2009, 01:49 PM
4s on a 5000kv motor geared 46/9 will be running ~55mph. Way too fast for such a high kv. I can almost guarantee you are gonna have heat issues. With that high of a kv, I would go no higher than ~25mph, which is a 5T pinion (not available). You can run that motor, just don't expect it to last long, and your batteries and ESC are also going to be stressed.
junkman
03.12.2009, 01:53 PM
Thats a neat motor mount, did you have it made?
03.12.2009, 02:09 PM
You could run batteries in parrallel 2s2p - This might give you better gearing...
03.12.2009, 02:42 PM
You could run batteries in series 2s2p - This might give you better gearing...
I like that, running a novak HV motor on LV (low voltage), funny. I still think a 6.5 novak would be a better choice...
And to get a 2s2p setup out of 2 2s lipos you would run them in parallel not series. Series would net 4s out of those packs.
whitrzac
Can't catch this...
whitrzac's Avatar
03.12.2009, 04:31 PM
hmm, that is a good idea, no need for a externeal bec ether...
I'll give the 2s2p setup a try
mabey I'll stick to my 3300s untill I can get a diffrent motor, I don't think they could deliver the amps needed to creat a ton of heat
with a 13t pinion I should be just were I want it, but what about the torque?
would turning down the epa on my radio help???
whitrzac
Can't catch this...
whitrzac's Avatar
03.12.2009, 04:52 PM
any info on this motor???
http://www.rctech.net/forum/r-c-item...ver-raced.html
03.12.2009, 04:53 PM
Not unless you get it for under $40 shipped - it is a feiago...
whitrzac
Can't catch this...
whitrzac's Avatar
03.12.2009, 05:00 PM
whats so bad about them??
03.12.2009, 05:06 PM
Well for that price you can get a new one almost - your money is much better spent on a relaible modern motor such as the medusa or a cc neu.
Medusas can be picked up around that price point and would be a better choice. If you want to get started they are a cheap alternative - just go cheap as you will end up replacing it.
whitrzac
Can't catch this...
whitrzac's Avatar
03.12.2009, 05:14 PM
what about the savage flux motor? there still made by CC, right? the seem to be foing for <$130 do they have mounting holes in the endcap, or do they have to be clamped?
http://cgi.ebay.com/Hpi-Savage-FLUX-...QQcmdZViewItem
03.12.2009, 05:23 PM
no they would be fine...
whitrzac
Can't catch this...
whitrzac's Avatar
03.22.2009, 12:30 AM
after its madin voyage, I have mixed fealings...
the pinion is a PIA to get on and stay on, I hope grinding a flat spot on the shaft solves this...
the esc gets a little hotter that I would like, 6(i think) LEDs after a 15min run, but yet the case wasn't hot to the toch and the hotest temp I got was 165 off of the solder posts. any sujestions on colling it down??
COGING!!!! its only a little going forward, but I can't back up at all, it just stutters
OMFG I have POWER!!!!
its at the track right now, so I'll get pics tomarow, but I realy like the way I layed it out
still sounds like a chainsaw...
whitrzac
Can't catch this...
whitrzac's Avatar
03.12.2009, 05:31 PM
so are they basicly the same motor as the CC neus?
