brushlessboy16
brushlessboy16's Avatar
04.02.2009, 05:33 PM
Ceases? im really confused at what your getting at, darn you and Chris with your enlish-ness
emaxxnitro
emaxxnitro's Avatar
04.02.2009, 05:34 PM
yeah heres the best one http://www.rc-monster.com/proddetail...MBO2200&cat=20 select motor only and mike will ship you one for 150. much better for a emaxx than a medusa as the endbells are closed. plus castle always makes good on the warranty
808E
04.02.2009, 05:55 PM
I have one that still amazes me but isn't being used if you are interested...
ambryatim
04.02.2009, 05:59 PM
Arct1k....you have a pm ;)
entjoles
04.02.2009, 07:45 PM
i had great luck with a hv4.5 and the mmm , in a e-revo , i geared it to novaks rec. and the temps where fine.
check youtube for a vid of mine on the track , it ran great
it will work good for now , go for it , and later get a medusa , the 6.5 will get good run times as well
http://www.rc-monster.com/forum/showthread.php?t=15511
http://www.rc-monster.com/forum/showthread.php?t=15064
ambryatim
04.02.2009, 11:13 PM
I see that you have the smaller shaft (1/8") HV, now you were running on 4S right??? Isnt the 4.5 5000kv???? If so, wouldnt that be like 74000rpm???? or was the old HV4.5 KV different???
entjoles
04.03.2009, 05:25 PM
yeah its a old 1/8 shaft motor , and novak says on their site its 5000 kv
yeah 4s
if geared according to novaks specs , it will run ok , i had no temp issues at all when geared with a 12t on the 4.5 motor , it was about 120f , and a 13 iirc jumped to 145f so i ran a 12t
also remember that a monster trucks trans has a gear reduction , not a great set-up but if you have the motor it will work fine
whitrzac
Can't catch this...
whitrzac's Avatar
04.03.2009, 08:05 PM
I had a novak hv 4.5, awsome motor for anything <1/8
escpesialy a slash the motor is defintly over 5000kv, it was faster than my MM 5700 motor
