Hyper 9E
Marvin
THE Paranoid Android
Marvin's Avatar
Hyper 9E - 04.16.2009, 09:17 AM
Hi
Just thought I'd show off my new Hyper 9E (it was on ebay a few weeks ago). Not much conversion on my part, but I'm sure people want to see it up close.
I'm running:
-A Medusa 36-60-2000 motor (doesn't look like there's much room for anything longer, a 70 maybe...)
-CC MMM V3
-Flightpower Evo 25 4350mAh 4S
-Futaba BLS-451
-Spektrum DX3R + Receiver
There's some really neat ideas on this chassis, like the 'centre' diff being right at the back, the proper radio box underneath the ESC mount, the fact that it's a completely new chassis plate - not with any nitro holes. The new big-bores it comes with - they look like they're about 20mm diameter!
And here come the pics (if I do it right anyway...)
In the beginning the Universe was created.
This has made a lot of people very angry and has been widely regarded as a bad move.
Marvin
Marvin's Avatar
04.16.2009, 09:20 AM
And the rest...
Notice that the centre diff is split horizontally for quick access - which is nice.
04.16.2009, 09:26 AM
IIRC the shocks are 17mm but certainly beefy...
Nice car...
Marvin
Marvin's Avatar
04.16.2009, 09:33 AM
Thanks
I think the outside diameter is 20mm - but inside you are definately right (17mm).
04.16.2009, 09:58 AM
Lloks good, that is a nice buggy!
How flexible is the chassis? I guess with the two ribs in the chassis it does not flex much?!?!
mjderstine
mjderstine's Avatar
04.16.2009, 10:24 AM
looks great man. can you get us some closeups of that driveshaft!
Marvin
Marvin's Avatar
There's barely any flex at all - more along the lines of a 1/10 electric buggy - no flex, but let the suspension do the talking, or something
Marvin
Marvin's Avatar
04.16.2009, 10:33 AM
Which ones? If it's the centre you're after, it's just one very long thick dogbone, and at the back there is a centre diff outdrive look-a-like coming out of the diff, and a U-shaped bracket as the centre diff outdrive to go over that.
Marvin
Marvin's Avatar
04.16.2009, 10:45 AM
Here's some pics of the rear driveshaft assembly
And of the centre driveshaft
delirium
04.16.2009, 10:56 AM
Looks really nice, how long is the center driveshaft? RTR weight?
Marvin
Marvin's Avatar
04.16.2009, 11:31 AM
Centre Driveshaft is about 20cm long, weight (without bodyshell) is 3360g
Electric Dave
04.16.2009, 11:46 AM
Thanks for posting those pix! Explains a lot.
How does the weight balance (L/R & F/R) feel to you with Motor and Battery in there?
Marvin
Marvin's Avatar
04.16.2009, 11:51 AM
It feels pretty well balanced front to back and side to side, better than my 8ight conversion anyway.
gixxer
gixxer's Avatar
04.16.2009, 02:10 PM
Very nice. Figured someone from here would get it. Was kicking myself for not bidding at the end what I saw the price it went for. Should be about the same when it actually hits the states though. Nitrohouse has them listed for $449.
Anyways how long is the battery tray? I ordered a neu 4300 6s pack and want to make sure it will fit. Also what size is the spur? I assume it will have a 40t like the nitro? Hoping larger will fit cause I really would like to put in a slipper or losi smartdiff?
thanks
Kyosho SC, tekin rs, D3 17.5
Hyper 9e, mmp,tekin 1900kv
Marvin
Marvin's Avatar
04.16.2009, 02:23 PM
Yeah, to be honest it should go to someone from the UK, because what I got it for was about Trade price + VAT (predicted), RRP would have been about $650 (equivalent). You get stuff so cheap in the US!
The battery tray is 175mm long (might stretch to 178mm - that is absolute maximum though!). Width is 46mm and you can have practically any height due to the bodyshell design.
Spur is a 40T, and you could fit probably up to a 44/46T in there - main problem though is that it uses very small diff cases (short ones), you'd be hard pressed to fit a bigger one in there - it also uses small outdrive bearings.
