speedracer1129
06.15.2009, 08:05 PM
By the way, what "Channel" are you refering to??
Metallover
RC-Monster Spudgunner
Metallover's Avatar
06.15.2009, 09:05 PM
That Miamiz finest channel.
speedracer1129
06.15.2009, 09:51 PM
AHHH!!! That is the car's owner user name. He frequents RC Universe.
Metallover
Metallover's Avatar
06.27.2009, 01:04 AM
Well, I made some headway today. I got a Quark 6000kv motor from linc and soldered it up. I think the pinion is around 26t. Once I plugged everything in I lifted it up and tested it with my 9.6v "test pack". It worked fine so I plugged in my flightpower 3s lipo. It worked too. My friend was over, and I decided to show off what a 4s pack would do. I gunned it and parts went flying everywhere! I ended up snapping a drive cup and bending a center shaft into a boomerang.
After that I thought I'd test it with rear wheel drive and the 3s lipo. The car we really slow and made odd noises in the [ball] diff. We took in it and after a few minutes we had the diff out. It seemed a little hot, so we temped it and it was at 160f! I guess the diff was slipping. After trying a few different things and stripping a ball diff screw, we took the balls out of one a took some CA glue to it.
Now I esentially have a spool I plan to put in the front after I get a new center shaft next week. I ordered it today when I picked up my ball diff rebuild kit that had the stipped screw in it.
With the spool in the back it spun out, a LOT. I couldn't get up half speed. it was embarrasing when a cop drove up and asked us how fast it was. I couldn't get it past 20mph! Well, I hope I have better luck with 4wd. I'll probably post up some pics but until then I'll update ya'll when I get some good runs in with 4wd.
06.27.2009, 01:07 AM
Well testing is identifying failures- your diff is one of them. Hope it works out for ya.
Metallover
Metallover's Avatar
06.27.2009, 01:10 AM
I *hope* the diffs hold up when there is 4wd. RWD must be too much for a ball diff with so much power behind it... I expect the diffs to do fine but your post will forever haunt me...
NoControl
NoControl's Avatar
07.03.2009, 12:07 AM
This may be a bit off and odd, but could you also use A123 cells and if so is 10c good enough or do they make higher C packs or higher then 2300mah?
E-revo MMM 2200 6s zippy 50MPH of pure fun and parts destroying powa!
Futaba 3pk more controller then anyone person needs
TC5 top speed drifter 21mph on crappacks and 40 on calc
Metallover
Metallover's Avatar
07.03.2009, 12:13 AM
a123 cells should be rated 30/60c. The ratings are different then lipos however. It is rated to how much current the cells can survive. The a123 cells don't hold their voltage under load like a good lipo will.
And for an update on the tc3, the parts were on order and I went to pick them up and everything at the hobby shop was being packed up. errr.. I was pretty good friends with the owner and now I have to drive 30 minutes just to get parts. Maybe I can pay for shipping and get them online.... But the parts aren't in yet so no progress..
NoControl
NoControl's Avatar
07.03.2009, 12:23 AM
Ok just wondering since I've been using some old nimh sticks on my tc5 but the area for the batterys have 2 peices of plastic that are screwed on and are basicly shaped to hold a custom "cell pack" like nimhs or a123's and since my nimhs are almost dead and I'm tired of the packs sliding around I was thinking a 3s3p would be nice , cuz it would fit perfectly, and it would be 9,9v and if I managed to get a MM 7700 I could "theoreticly" hit 100mph, but the fewest and least expensive cells on fleebay were 2300mah 10c, 8 for 68$ shipped.
Metallover
Metallover's Avatar
07.04.2009, 12:50 AM
FINALLY pic. Has the flightpower evo30 3200mah 3s lipo, quark 4t motor, MM, and an external bec in there. Note missing driveshaft.
speedracer1129
07.04.2009, 01:29 PM
Looking good....few things:
- You need stiffer springs
- Sway bars (rear for sure)
- Definately foam tires!!
That should help you keep a handle on the car. By the way, what body are you planning to run??
07.04.2009, 01:36 PM
Clean your RX wiring-
Also your tires are on backwards.
Metallover
Metallover's Avatar
07.04.2009, 01:52 PM
Thanks. I'll put those on my list. I'm running the mazda body on the previous page unless you guys can find me a really aero body.
Thanks Ian!
07.04.2009, 02:36 PM
I like your motor wiring.
Metallover
Metallover's Avatar
07.04.2009, 02:44 PM
Yeahppp I got lucky on that...
