boss 302
01.16.2006, 07:13 PM
nice truck ;) looks like you had a lot of fun at the beach.
how fast is it and how many cells were you using
R00ST
01.16.2006, 07:28 PM
I havnt GPS'd it yet, but I was running 14/66 on 14 cells. I would estimate it to be high 30's.
squeeforever
squeeforever's Avatar
01.16.2006, 07:59 PM
14/66? seems kinda low huh? im gonna be running me evo on 16 cells on a 8xl/9920 and kind need to know were to start. i was thinking about 16/66 or maybe 18/66....help please!!
R00ST
01.16.2006, 08:12 PM
Well keep in mind the size of the tires I was running. If you are running standard size maxx tires expect to bump the pinion at least two teeth. (so yes 16/66 would be a good starting point)
I actually thought I would be geared WAY too low with the 14/66 setup, but actually ran the entire time with that setup as it ran pretty well, and the top speed was plenty fast.
squeeforever
01.16.2006, 08:33 PM
what about temps?
R00ST
01.16.2006, 08:35 PM
I didnt bring my temp gun with me, but temps seemed just a tad on the hot side. I am not very accurate guessing temps so I wont guess, but the motor was pretty toasty, while the controller wasnt too bad. Hopefully it will all be back together soon and I can do some more testing and have more accurate answers for you.
Dafni
Dafni's Avatar
01.17.2006, 03:16 AM
I could bet with one or two more teeth on your pinion the motor temps should come down. (even with the mashers, you run an 8XL after all) Give it a try.
slow-stampede
01.17.2006, 03:01 PM
I'm running a 9xl with 18 cells and my motor is blazing. I've tried a 14/66 and it was hot shortly, then I went to a 18/66 and it's still burning up, but not as quickly as the 14/66. I think I have to use a fan, there's no way around it.
squeeforever
01.17.2006, 03:29 PM
try a 16 and if that doesnt work you might have to go higher than a 18. i have heard of people running 18/66 on a 7xl with 18 cells...
Dafni
Dafni's Avatar
01.17.2006, 03:30 PM
Slow-pede, I say you are still undergeared! A 9XL should not sweat on 18 cells in your maxx. Try a bigger pinion or smaller spur.
Edit: Squee, that's right. I have heard people run up to 20/51 on a 9XL. I have no experience with the 9XL, but I would say 18/66 is way undergeared.
slow-stampede
01.17.2006, 03:32 PM
Whoa, really?! At 18/66 the motor is blazing hot, speedo is pretty hot, and the batteries are warm. Hmmmm, maybe I'll have to go smaller on the spur.
Dafni
Dafni's Avatar
01.17.2006, 03:34 PM
I hope somebody confirms my info!
Coolhand has a 9XL. Leroy, watyousay?
slow-stampede
01.17.2006, 03:36 PM
It's actually a revo...might weigh more, but just for FYI.
squeeforever
01.17.2006, 03:47 PM
yea, if im not mistaken leroy runs his on 18 cells with a 22 tooth pinion. although im not sure.
coolhandcountry
coolhandcountry's Avatar
01.17.2006, 06:26 PM
I have ran the 9xl with a 20 51 mod 1 on 18 cells. It did run warm. I have ran a 7xl on 22 66 gearing on 18 cells to. It also ran warm. I have not problems with running a 9xl on 16 51 gearing 1/8 diffs and 16 cells or 18. I can run the gearing with a 9xl on 12 to 18cells with no heat problems in 90 f temps. no fan.
Peace!
Country
Help support the
Rc-Monster
Buy here
