Thread Tools Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
09.18.2009, 07:46 PM
Hell's yeah! That is awesome. Can't wait for more
redshift
RC-Monster Square Tube
redshift's Avatar
09.18.2009, 09:34 PM
WoW.
Schweeeeeeeet
I am wondering if metal gears will hold up on that!
Better do something with the radio.. range issues could be fatal w that thing...
At the least you could take out a decent sized evergreen
Sounds beastly!
big greg
09.18.2009, 09:40 PM
your gonna have a problem if those gears stripped out with that little bit of power, wait till ya start to romp on it!
aqwut
Brushless Heavy Weight....
aqwut's Avatar
09.18.2009, 10:41 PM
It sounds so cool.... Did you really think the plastic gears would last??
I had my fingers crossed.. I have to weigh that thing, it's atleast 35Lbs...
Me too, just finished the battery mounts... now I just have to make a mount for the ESC and I'm all set..
WoW.
Schweeeeeeeet
Sounds beastly!
I'm suppose to send the module back to spektrum to change the antenna wire. But I have races for the next few weeks and unable to send it yet...
Lookin' at the Metal gears right now....I might keep one of the gears plastic.... but I have lots of gears(came with the truck), I want to see which one keep dying... I'm sure, it'll be that same one all the time...
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
redshift
redshift's Avatar
09.18.2009, 11:02 PM
Just a few thoughts I had aqwut, the intermediate gearset (idlers) seem like a potential trouble spot. They're only supported on the inboard side, any bearing slop will translate into severe wear on the gears. I realize this was sort of a bang-together and I LOVE it, just thinking longevity. If you notched the tray a little more it the bevel drive could accomodate a single large spur, and the pinion could be moved inboard on the motor.
Also I was wondering if there are any belt drive options that would work here? Just for motor-to-bevel drive. You mentioned you want to keep it stock looking-ish lol. I just hope you aren't limiting yourself as far as reliability?
aqwut
aqwut's Avatar
09.18.2009, 11:06 PM
Hey, thanks for the input... I wondered why only that gear was worn... The guy I bought it from used a 24T gear.. it's suppose to be a 25T... I just read it on website a few minutes ago... I will give it a few more shots with the plastic gears, but I will be getting the alloy motor and center differential mount...
big greg
09.19.2009, 01:13 AM
so the gear that stripped was supposed to be a 25t? if the mesh wasnt tight that would make sense why it stripped so easily
Ryu James
Ryu James's Avatar
09.19.2009, 02:11 AM
love the video aqwut! ramtech or largescale both have steel gears for the ramp. as i am sure you know. as well as the alu. gear plate and diff mount. i was surprised at how agile it seems. just looking at these 1/5s you think they would be real sluggish and clumsy but it seems the opposite. i cant wait to drive mine.
Jammin SCRT10 Neu 1512 1y
aqwut
aqwut's Avatar
09.19.2009, 11:16 AM
Yeah, it was suppose to be 25T meshing with a 25T (50T total) for the transfer gear and 60T total for the spur/pinion gear..
I'm liking this rampage a lot... the more I work on it, the more I start to like it.. Parts aren't too expensive Either..
I'm not too big a fan of metal on metal gearing... but for this beastly machine, I would probably get metal gearing for the transfer gear and for the Spur gear(once I find the right gearing).
I currently have 25T with 35T on there right now.. I will try 29T & 31T today.. see how much I could push the 100A ESC... ESC was barely warm with the 25/35T Gearing...
aqwut
aqwut's Avatar
09.19.2009, 09:40 PM
This is how I will be mounting the batteries.. battery mound and tray...
I used up all the stock holes... Did not modify the chassis in any way...
I updated the battery tray...
aqwut
aqwut's Avatar
09.19.2009, 09:43 PM
Here's the rest of the pictures of the finished truck..
Here's a Video, it's a little DARK.. will get a day video tomorrow...
5 minutes of runtime in the front yard, and 7 minutes of runtime in the backyard..
Lipo took about 2150mAh charge... so I should get about 20 minutes with this gearing... 27/33.. and 12S1P 5000mAh...
[youtube]ouIQYzBzdqw[/youtube]
After the run the motor was 34 Deg Celcius and the ESC was 39 Deg Celcius...
Metallover
RC-Monster Spudgunner
Metallover's Avatar
09.19.2009, 10:04 PM
Setup looks spot on! With most of the 5th scales I've seen, it was like putting a fiegao S motor and a MM in a savage. This looks more like putting a MMM in a savage! What it should be. Temps look really good too. Looking forward to more videos if they get made!
mschaffer66
09.21.2009, 12:34 PM
What ESC are you running in that thing? I'm assuming its probably a high amp boat esc?
aqwut
aqwut's Avatar
09.21.2009, 01:52 PM
Originally Posted by virusss View Post
aqwut, my baja weight ready to run 9.5 kg...for me 2230 is too much, the drivetrain EXPLODE :)
It's never too much power.. but it would be awesome to see...
100A 12S HobbyWing ESC..... Works awesome, Surprisingly...
redshift
redshift's Avatar
09.19.2009, 10:34 PM
Total envy.... and what's up w the shorts? It's 30 (0C) here! Is it really that warm up there....
Truck came out superb man... howbout a shot w the body on tho
Fantastic work!
