jas21373
11.10.2009, 10:36 AM
Originally Posted by fastbaja5b View Post
Mamba Max is a 3s ESC
running it on 5s =
my MM's have had 50+ 5s packs put through them ,geared right they have never failed me
Unsullied_Spy
Unsullied_Spy's Avatar
11.09.2009, 02:47 AM
4s is fine, but 5s is begging for trouble IMO. +1 for the MM Pro, they seem solid and are built to handle the voltage.
jsr
11.10.2009, 02:24 AM
I had a MM with external BEC on 4s in my truggy and it got HOT quick, even with a 40mm fan on it and another 90mm fan above it. I wouldn't run it over 4s. MM on 3s or 4s in a buggy is great, on a truggy, it can be tough on that little ESC. If you can keep it cool, then it will work fine on 4s. The problem is keeping it cool.
coolhandcountry
coolhandcountry's Avatar
11.10.2009, 10:44 AM
160 sounds warm but not overly hot.
I hope it is kind of warm outside for these temps.
The Dan
The Dan's Avatar
11.10.2009, 05:58 PM
Maybe I should just do it, since this thread is generating some good debate on whether or not it will work. Problem is, I'm a cheapass and don't wanna spend $50 on a Zippy 5S pack.
I may end up just going with 4S/8XL. That worked well in my old E-Revo. Sure, the motor runs hot, but that's what my leftover HV heat sink is for. And I already have four 2S packs to play with.
jsr
11.10.2009, 10:10 PM
I think an 8XL on 4s would run fine. Just don't gear for too high a speed to keep your MM from cooking. Get dedicated fans for both the motor and ESC. Keeping the motor cooler will help keep the ESC cooler also. I ran my MM with a 6XL on 4s...much higher rpm. Great power and speed, but both ESC and motor got hot quick. Running it on 3s and not gearing it too aggressively would've probably kept it a decently running setup (not too hot). Good luck and have fun.
