Thread Tools Rating: Thread Rating: 16 votes, 4.75 average. Display Modes
Moller123456 !
05.11.2010, 03:00 PM
Thanks:D Got a friend to pick some traxxas bearings up for me, cause i need them before sunday... but will take a look at the links:D
Thanks:D everyone here is so kind
Found out why the bearing was smashed... the hole in the motor mount /center diff mount was too small, so i had to push it very hard in. and took me 1 hour to get it out
  Send a message via MSN to Moller123456 !
jholthus
05.12.2010, 05:00 PM
Just got mine together today. Man it's a nice setup. Mike did a great job with it. Only thing I really modified was the tray. I cut a notch in it for my battery wires so I could lay the battery flat and dremeled a "tunnel" under it to run the wire going from the ESC to the RX. Personal preference there but I think it turned out nice
Chadworkz
UE Supermaxx Addict!
Chadworkz's Avatar
05.13.2010, 12:47 AM
Very cool...I absolutely love clean & tidy wiring, awesome job!
-Chad
PM ME IF YOU HAVE THE BELOW:
BlackedOutREVO
05.14.2010, 03:20 PM
I just read this whole thread last night. Looks like a awesome little car
But I remember talk about rollers on ebay for cheap. The only ones on there now are for like 225 bucks, were there cheaper ones?
simplechamp
simplechamp's Avatar
05.14.2010, 09:53 PM
It seemed like people were making out pretty well by buying the RTR and selling off the nitro stuff and DX3S system. Depends if you want to put up the money and deal with selling the stuff.
FG101C
05.16.2010, 06:35 PM
So far I've been on the track about five time's. Truggy has been great, I mounted a set of Pro-Line 30 series Bow-Ties to the Losi wheels for this truck and it made it steer so much better. First broken part today though, one of the front cvd's right where the pin fastens it to the axle. Not sure if it's a week point or I tapped a pipe wrong. Bad part is they are $18.99 at A-Main, hopefully it is a one time thing and not a constant ocurence.
Chadworkz
Chadworkz's Avatar
05.16.2010, 06:48 PM
I can't wait to get one and convert it to brushless. I am going to install a crazy-powerfull BL system in it and turn it into a rocket-ship, just stupid-fast!
-Chad
95ROLR
05.16.2010, 08:08 PM
Had my Ten-T out with MMM 2650, 4s 30c 5000 turnigy and 26t pinion... Also mounted a set of badlands on some JC wheels. The truck is simply too fast. The motor, speed control and battery aren't hot, or really all that warm, but the truck flies. I would almost say it's overkill as there's no instance today that I wanted to use all of the top end speed.
I think I just may switch to a much smaller pinion :)
Muggydude
05.17.2010, 11:57 PM
And dial some speed out with Castlelink.......
simplechamp
05.18.2010, 07:08 AM
You can't really reduce the speed with the CastleLink. You can control the punch, and adjust the throttle curve, but that just changes the way it gets up to speed, the top speed will remain the same. The only way to truly reduce speed is to drop the gearing down, use a lower kv motor, or reduce the voltage. I guess you could adjust the endpoint on your radio, but the previously mentioned methods are much better choices.
nitrostarter
nitrostarter's Avatar
05.18.2010, 09:47 AM
I would suggest a lower Kv motor. The 1900kv sounds to be the right wind for 4s running.
N. Rustler conversion
Moller123456 !
05.18.2010, 04:12 PM
am i really the only one with the center diff bearings problem? How did your bearing fit in mikes mount?
I have so far broken 1 rim and 4 center diff bearings:@ and abit of the body (not that bad)
95ROLR do you have some pics with the bandlands? And is it the MT or buggy badlands?
bryan
bryan's Avatar
05.18.2010, 04:55 PM
Everything went together smooth when i converted mine.The only thing i have broken so far is a rear plastic hub.Big jumps and cartwheels tend to do that.
95ROLR
05.18.2010, 08:08 PM
Buggy Badlands on Rulux buggy wheels.
Moller123456 !
05.19.2010, 03:35 AM
Wooow looks nice:D i cant find out if i should get them, or just the original (and smash some rims)
