Go Back   RC-Monster Forums > Support Forums > Novak
fastbaja5b
fastbaja5b's Avatar
03.31.2010, 02:27 AM
I think the VXL ESC is quite underrated. I have one now that's fairly untidy, button got stuck so I opened it up and took it out so now to turn it on it's a screwdriver through the hole job, told Traxxas and they're sending me a new case :) Ran a Medusa 36-70-2000 motor last night with one no problems at all, no cogging, on 3s Lifepo4.
ESC didn't even raise a sweat.
Check your sensor motor wire is plugged in correctly. Does it run without the sensorwire?
Say Less, Do More.
timaneli
03.31.2010, 06:20 AM
on mine vxl both motors run with sensor connected and working with zero cogging..
you are what you race!!
ebomb
03.31.2010, 09:16 AM
are u using 1/8 shafts or 5mm and is the older vxl or waterproof 1 thanks
timaneli
03.31.2010, 09:55 AM
yes is a 5mm 5.5 hv motor on a hyper 10 sc short truck and is the waterproff vxl.
i usually run on 1/8 tracks and no heat issues until now.
motor and esc rarelly warm.
vxl is a great esc because can handle to 200 amps continuos and is super simple, and have temperature cut off on esc and motor.
i have race with this setup to and with good results.
no need to buy or use mmp or others..
