05.20.2010, 03:20 AM
ok now i have a new question the ground out here is covered in 1.5 to 2 inch gravel is there a set up that will help on this stuff, so far i have started to run
badlands tires
RPM front and rear A-arms
alu shock mounts
a center one way drive shaft (to stop wheelys)
i have also added the push rods to stiffen the rear bulk head. I haven't broke anything but bodies, but my friend can turn alot sharper at speed than i can just trying to figure it out
UE Supermaxx Addict!
05.21.2010, 01:29 AM
What rockers are you running? What color springs are you running? What weight oil are you running? DO you have anti-swaybars?
-Chad
› PM ME IF YOU HAVE THE BELOW:
› VBS, CVDs, GM Single-Speed, OTB, Ultramaxxed, Super6, Strobe, Sprong, CNR Brake, UE Hex, DUH Towers, Predator, Blackbird, GA Blue Screws, HCR F/R Skids & Mutant
05.21.2010, 08:54 AM
ok i am running 45weight oil in the shocks, p2 rockers in the back. LT rockers in the front, and tekno swaybars
the biggest problem is while turning even at low speeds the inside wheels lift off the ground. So i end up almost stopping for corners.
05.21.2010, 09:01 AM
Well, you need to switch to the same rockers (I recommend P1) front and rear, the middle-weight Tekno swaybar bars, 55wt oil in the front, 60wt oil in the rear, and Traxxas VDP piston set (off-road position) in all four shocks.
-Chad
05.21.2010, 11:37 AM
thanks i will try all that out it will take while for the VDP piston set but thats just how it goes
05.21.2010, 01:38 PM
Yes, no mixing rockers. And as Chad said, thicker oil and the VDP kit will help too.
R.I.P. Muggy, Rustler, VXL Slash
EFlite Blade MSR Heli (Slightly modded)
1/16 BL E-revo
8-t 2.0, OS Vspec with Speed conrod
Carbon Fiber Revo 3.3 Coversion Madness!
05.21.2010, 01:39 PM
Oh and Chad, any updates on the ESC plate?
1/16 BL E-revo
05.21.2010, 04:36 PM
Took mine off, have the new template drawn with the holes for the TRX MMM hold-down located, I just have to cut it out and smooth it up!
-Chad
05.21.2010, 05:14 PM
Cool, thanks! As I said before, there's no hurry. But glad to know it's coming along.
1/16 BL E-revo
05.22.2010, 02:50 AM
JThiessen
I live in WA state but i am in afghanistan right now with the 1-503rd
05.22.2010, 08:51 AM
Originally Posted by medicineman
JThiessen
Paratroopers? I don't know how I know that......weren't they featured in "Band Of Brothers"?
05.22.2010, 12:53 PM
yeah we are airborne
the 1-503 was in band of brothers they were at the eagles nest in the end in front of the fire place, also a big and rich song The 8th of november now they call us the "lost ranger bat" don't know why
05.22.2010, 03:07 PM
My Grandfather was a Paratrooper in the 11th Airborne, and served in the Philippines, New Guinea, Leyte Gulf, and was in Japan after the war had ended, helping with the clean-up. Along with many other medals, he received the Purple Heart, and both Bronze & Silver Stars.
My Dad was in the 6510th Air-Base Group, but was never deployed for action.
I tried to join the Marines as soon as I graduated, but I failed the physical due to breaking my neck during a football game my Senior year (broke 2 vertebrae, fractured my skull, and had a Grade-3 [major] concussion with retrograde amnesia [5 days]).
-Chad
05.22.2010, 04:17 PM
Yeah i have no family history of service but i have deployed 2 times to Iraq and three to Afghanistan, got a few awards but nothing like your grandfather I am Medic now in Afghanistan., How do you do that in football, you guys must have had alot bigger players than we did.
05.23.2010, 09:13 PM
First off, I want to thank you for doing what you do, you have my deepest gratitude...and going back as many times as you have, that puts you way up there as one of the best people I know.
Well, I was a running back, so because of my speed and power, I also sometimes played special-teams (kick-off & punt team and kick-off & punt return team). Anyway, during a kick-off where we kicked off, I ran down to try to make the tackle, and when I hit the guy, with both of us running full-speed (I ran a 4.6 forty), he lowered his head (I was shorter than him) and we hit in such a way (the top portion my face mask & the top of his helmet hit) where all of the pressure & force was focused on my forehead (fracturing my skull), as well as bending my neck backward (breaking my neck), and the rebound of my brain hitting the inside of my brain-case (I forget what that's called) caused the concussion and amnesia. I was paralyzed for a short time due to the swelling, but there was no permanent spinal cord damage.
-Chad
