E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
06.09.2010, 10:25 PM
Originally Posted by loa View Post
Went with 6.5mm bullets from Castle I had lying around, separated by shrink tubing and glorious duct tape!
:-D
Loa
Duct tape is not the material to use here as it does actually contain some metal. Use electrical tape
loa
06.10.2010, 06:51 AM
I know: the duct tape separates the wires and is not on the bullets themselves (which are covered by shrink wrap anyway).
Loa
nastety92
07.17.2011, 08:17 AM
Is there any reason that Deans Ultra should not be used in this application? 4-5s is that to much for them?
I'm using Deans Ultra on everything and have no problem with them once soldered.
Thanks,
Nick
Tamiya TRF801Xt-e
JThiessen
JThiessen's Avatar
07.17.2011, 12:54 PM
Thanks,
Nick
I much prefer the EC3's over Deans - much easier to assemble, and easier to plug and unplug....
Nard Cox
n00b
06.10.2010, 10:02 AM
I realize that the big 8awg wires of the 5S lipo won't even fit inside the smallish Traxxas plug.
They actually do, I have it on two of my 4S 5A 30C packs. It's a pita to solder though. Yesterday I started converting to EC5 .. wil continue today.
sabongi
06.10.2010, 10:29 AM
Using EC5. Just like a 5.5mm bullet, but with housing. Perfect for me.
FG101C
07.16.2011, 03:30 PM
Why in the hell am I having such a hard time getting the ec5's to sit in the housing on the battery side? I got the esc side no problem.
Do you do the battery side the same way or do you run the housing over the wire then solder the bullet and pull it on? I've tried both ways and can't get it to work for me. Can't believe there's not one video of someone doing ec5's, ec3's all day but they are somewhat different.
HELP!!!
brainanator
brainanator's Avatar
07.16.2011, 05:41 PM
I use 8AWG wires on my traxxas plugs, you just gotta get them in there right.
can't help with the EC5s, never seen them, should just snap in right? Might have to pull pretty hard, make sure no solder is overlapping a snap point.
simplechamp
simplechamp's Avatar
07.16.2011, 09:59 PM
A bit off-topic, but with increased popularity of 1/8 electric I'm surprised Dean's hasn't come out with a new larger connector. I like the Dean's design, I'd love to see them come out with the same connector about 1.5X larger, Dean's Ultra XL. Maybe add some ridges like on the knock-off ones.
FG101C
07.17.2011, 01:26 AM
Was just thinking the same thing. I finally got the battery side ec5 plugs on. The brand I got required me to put the housing over the wire then solder the bullet then pull the housing on. Problem now is they won't plug all the way in to each other, so I ordered from Castle enough 8mm bullets to do my Baja and make two charge adapters for it. Wish I didn't waste all that time with those ec5's.
simplechamp
07.17.2011, 10:39 AM
It's not so much the voltage, but the current. The power loss due to resistance is I^2*R. By switching to a connector with lower resistance you can reduce those power losses. Same thing goes for switching to thicker wire and/or shorter lengths of it. Dean's work fine, but there are connectors available that have lower resistance. It really comes down to how concerned you are with efficiency. Any losses at the connector are being taken away from driving the vehicle.
In terms of voltage, a higher voltage setup is actually better for reducing connector power losses (compared to a lower voltage setup producing the same power e.g. geared for same speed). It's the same I^2*R equation, this time reducing current instead of resistance.
FG101C
07.17.2011, 11:03 AM
My gut told me to stick with Dean's, should have listened.
07.18.2011, 07:33 AM
I found EC5s to be incredibly easy to solder and assemble- first the bullet goes onto the wire ( with a big fat iron- I use a 75watt weller ), then the bullet pushes into the rear of the blue housing ( female bullet in the larger housing & goes on the battery ) and clicks/ snaps in place = job done. They are much easier to solder than deans for me, and easier to pull apart wiht my stubby fingers...
07.17.2011, 11:17 PM
I have used deans on just about everything (couple of traxxas plugs but I really do not care for them) I have and have not had any issues with them.
That beaing said we do need a better connector for high amp draws. The boat guys use bullets, and they draw big. Something like an ec 6 or ec8 would be nice.
x-y
x-y's Avatar
07.20.2011, 05:24 PM
after have much problems using deans and small bananas ...... I use the polymax 5.5mm bananas ........... the best connectors I used ......
SWORKZ BE-1, LEOPARD, HOBBYWING, GENS ACE, SANWA VX, FUTABA 3PL, MBX5R/T, RB5SPSL, FG MONSTER, TC5R, 808E, HYPER8, TF5, ZX5, NANO-TECH, HYPERION, 620DMG, ECO6-10, TEAM-IHOBBIES
