Go Back   RC-Monster Forums > RC-Monster Area > Product Reviews
Thread Tools Rating: Thread Rating: 12 votes, 5.00 average. Display Modes
feistyacorn
feistyacorn's Avatar
01.13.2011, 03:42 PM
What are the dimensions on this charger?
SunnyHouTX
SunnyHouTX's Avatar
01.13.2011, 03:41 PM
Do you think the CC motor bullets are long enough? What are you using? And the fuse block is good? Thanks Romano.
SunnyHouTX
SunnyHouTX's Avatar
01.13.2011, 03:53 PM
About 6"x7"x4"
feistyacorn
01.13.2011, 04:17 PM
Originally Posted by SunnyHouTX View Post
About 6"x7"x4"
Thanks! Im still dreaming about getting this charger. Someday.....
snellemin
2 KiloWatt RACER
snellemin's Avatar
The fuseblock is nice, as you can attached multiple charge leads/connectors to it.
I use the 4mm bullets from the cheapo Chinese lipo packs that come with 10AWG wires.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
SunnyHouTX
SunnyHouTX's Avatar
01.13.2011, 04:26 PM
I'm going to give the ones I got a chance first. Then I might have to go to what you're using. Good thing the fuse block is good: I ordered two of them.
40amp Safe Charge Wires For CellPro PowerLab 8 Balance Charger.
MindThoughts
40amp Safe Charge Wires For CellPro PowerLab 8 Balance Charger. - 01.13.2011, 09:51 PM
These 40amp wires are also available now as well :)
Direct Link:
http://www.fmadirect.com/detail.htm?...410&section=91
Below is a copy of an E-Mail I received (I signed up to receive new product notifications).
New Stock at FMA Direct
Cellpro PowerLab 40A Banana Plugs
$14.95
New 40A cables are required when parallel charging 2 or more packs on the new PowerLab 8 V2. The new V2 firmware is available to download if you want to upgrade a PowerLab 8 V1 model to get the full 1344W output power of V2.
Free V2 PL8 Charge Control Software (CCS)
Now shipping Cellpro PowerLab 8 V2 chargers and combos on the Revolectrix website.
Hyper 9E And Losi 8ight-E. Each model with Full Matrix Concepts Inc Carbon Fiber Chassis & Kit. Xcelorin 2100kv + Xcelorin ESC & 1409 1Y Neu/Castle + MMM. 1344watt 40amp PowerLab 8.
SunnyHouTX
SunnyHouTX's Avatar
01.13.2011, 09:59 PM
Saw them Joseph but it will be cheaper to build my own. Heck, I might even do stackable ones since I've got two fuse blocks coming. My local car stereo shop sells 12awg and 10awg wire for cheap and I've got a ton of male and female 4mm bananas so I'm all set.
So I've been playing with the charger for the last couple of hours... LOVE IT! Discharging two packs at a time at 40A (total) is amazing. Dumping it into a car battery so the fans rarely come on. It's very eerie to see 35A - 40A on the CCS on screen but no noise from the charger! Just finished discharging two 5200mAH 2S packs in 17 minutes or so... ridiculous
SunnyHouTX
SunnyHouTX's Avatar
01.14.2011, 03:00 AM
Amazing... pulling 46.5 Amps from the fleaBay power supply at full voltage doing a 40A recharge from storage (3.8V) on two 5000mAH 3S packs. Packs hooked up in parallel/daisy-chained. Took less than 13 minutes, with a total of 7311mAH stuffed back into both packs in that time frame. EC5 connectors between the charger and the power supply were at 95*F and same for the stacked bananas going to the batteries from the charger. Should be fixed with the new ones I plan on making soon.
snellemin
2 KiloWatt RACER
snellemin's Avatar
01.14.2011, 11:09 AM
You can see your 1.1s allready heh.
SunnyHouTX
SunnyHouTX's Avatar
01.14.2011, 11:16 AM
Oh yes! gonna be interesting.
How To Charge At 40amps 1344watts. Powerlab 8 Battery Workstation.
MindThoughts
How To Charge At 40amps 1344watts. Powerlab 8 Battery Workstation. - 01.14.2011, 09:54 PM
Very very nice :)
BIG-block
03.26.2011, 02:25 AM
Can anybody tell me if this charger can measure the internal resistance of the cells like my friends iCharger. I like the PowerLab8 more but would really like that feature as well. Just want to know before I hit the "BUY" button.
Powerlab 8. 1344watt 40amp charger.
MindThoughts
Powerlab 8. 1344watt 40amp charger. - 03.26.2011, 07:54 AM
Yes :)
snellemin
2 KiloWatt RACER
snellemin's Avatar
03.26.2011, 10:23 AM
Yes it does.
