crazyjr
crazyjr's Avatar
04.22.2006, 09:49 PM
Hey GriffinRU, I just recently aquired a Novak HV-Maxx brushless system and within minutes of running it for the first time the Magnet slipped on the shaft. As i fixed it with JB Weld( no warranty) I tried to find the sensors and couldn't. Could you explain how the sensors work with nothing to key into on either the magnet or the shaft? When i think sensors i think revo Optidrive, but i'm sure it could be a solid state setup as well. So could you please enlighten an old newb? thanks
GriffinRU
04.23.2006, 09:25 AM
BL motors use magnetic feedback. 3 sensors, based on Hall effect, placed 120degress apart generate signal for ESC everytime magnets pole passes by. Attached picture shows Novaks sensors, located inside can.
Artur
Serum
Serum's Avatar
04.23.2006, 03:55 AM
Yeah Artur!! this would be awesome.
I would love to drive a 10XL on 18 cells sensored, it is possible to get the hvmaxx esc modified to run on an higher voltage, right?
GriffinRU
04.23.2006, 09:40 AM
16 cells, even without mods, should be fine, using correct wiring (6 cell on capacitor side, the rest on opposite). But more then 16, I need to investigate this possibility, now hopefully (still working on sensors) I have a motor to play with.
After solving initial problems, future upgrades/modifications would be addressed as usual. :)
Artur
Serum
Serum's Avatar
04.23.2006, 09:47 AM
16 is nice. what is up with the 6cells on the capacitor side? is it a BEC issue? or are these cells used for feeding the processorboard?
Keep us updated please, this is a very interesting project.
Are those sensored feigao's easy to get?
GriffinRU
04.23.2006, 10:03 AM
Both, BEC and ESC power, one is less important but second is prone to overheat the PCB.
It is possible :) but is it easy or not I am not sure, sorry for not clear answer.
Artur
crazyjr
crazyjr's Avatar
04.23.2006, 09:57 AM
Ok thanks, i saw that but thought you needed a rotating assembly for the sensors, like the Revo Optidrive system. But if it runs on magnetic feedback, wouldn't it be similar to a sensorless except sensorless doesn't use a circut board to detect movement?
GriffinRU
04.23.2006, 10:07 AM
Sensoreless based on feedback from phases, which only exists when motor spins, while sensored feedback doesn't require rotation to point out rotors location.
Artur
maxxdude1234
maxxdude1234's Avatar
04.23.2006, 10:43 AM
Artur
....And the slower the motor spins, the smaller the 'back emf', so the less easy it is for the controller to detect the rotors position - hence cogging at low speeds.
coolhandcountry
coolhandcountry's Avatar
04.23.2006, 12:10 PM
If I read correctly some where. Can't you bypass the first 6 cell group and run a ubec to power it. The run the 16 cells like in a series on the other wires. The main hot and ground wire.
GriffinRU
04.23.2006, 12:45 PM
No.
There is no way to substitute built-in power for logic and brains with external power without modifications on PCB.
Artur
GriffinRU
04.23.2006, 01:44 PM
Ok, it is working now. Almost plug and play :)
Requires some tweaking on sensor side, I will share info with Feigao, hopefully it can be resolved.
So far works as expected. Too bad its raining outside.
Artur
coolhandcountry
04.23.2006, 01:51 PM
Well is other companies going to make a sensored esc. I would hope so. I would like to see a 8s lipo capable esc with sensored smooth running.
Red350DropTop
04.23.2006, 02:46 PM
I have got a bunch of new stuff coming for my maxx. 977 charger, 9L and a HV-Maxx setup. I will try out the HV-Maxx and then I think I am going to try the 9L on it as well. Could be a month though, but I enjoyed this writeup Arthur.
12 Cells, 6XL, 66t Spur, 21t pinion
GriffinRU
12 Cells, 6XL, 66t Spur, 21t pinion - 04.23.2006, 03:49 PM
Next would be mods on ESC.
By the way do not use reverse with Novak HV-Maxx or use it carefully, because going from forward to reverse is safe but going from reverse to forward... you can snap everything in your truck with big motors :)
Artur
P.S.
Thank you
__________________
Run quietly and have plenty of power.
Brushless. It rules.
www.rcpics.net/members/coolhandcountry
I hope so...
