Jahay
02.24.2011, 08:02 AM
HAHA FG... maybe that is the case...
I also checked the australian site... but they wont ship internationally :(
BUT I REALLY APPRECIATE YOU LOOKING !!! THANKS
im going to email integy.. .if they can do replacements for a good price, then awesome if not.... I am actually liking the lincs method with the nut system.
simplechamp
simplechamp's Avatar
02.24.2011, 03:41 PM
OFN36171 and OFN36640, 4mm hingepins for Ofna LX-One are a possibility. Have to email Nitrohouse to get the lengths. I think 36171 will be too long, but 36640 might be close.
EDIT: Nevermind, found the lengths, one is like 74mm and the shorter one only 38mm.
You could use one that is too long, cut one end down to length, and then re-make the slot for the c-clip? Like chuck it into a drill press and use the edge of a fine file. Using a screw is an easier solution I guess.
FG101C
02.24.2011, 05:55 PM
You could use stainless rod, cut it 60mm, thread 5mm on each end and use locknuts. Did that with my losi 8t because it would bend the rear outer pins, never bent a stainless one.
