Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
gtxracer
HOOH HUAH HOOH! Aww Baby!
gtxracer's Avatar
09.09.2011, 09:00 AM
Were you running 6s when the Mamba XL blew up?
:D
NickRummy
NickRummy's Avatar
09.09.2011, 09:06 AM
I never even got a chance the run the Mamba XL. I had soldered on 8mm bullets to it and was getting ready to test and then Castle issued the recall so I sent it out. Truck has never been ran.
I will be using 8s on it though.
gtxracer
gtxracer's Avatar
09.09.2011, 10:02 AM
I can't believe that thing only handles 8s...wow. I'll try my rx8 on 6s I think. I'll have to give Tekin a call to see if the rx8 can unofficially handle anything above 6s but it's still a lot of power. Have you considered using a rx8 in the meantime?
:D
NickRummy
NickRummy's Avatar
09.09.2011, 10:14 AM
Nah I'm a Castle fanboy
NickRummy
NickRummy's Avatar
09.14.2011, 09:02 AM
Finally got around to fitting the hub on! Hub on the XL axle with pin through both.
O-ring on the hub to hold pin in place and then with the wheel mounted.
Gave the machinist the go ahead on producing more so I'm getting anxious to see a full set in use!
thzero
09.14.2011, 09:23 AM
Looks very clean. This is what HPI should have designed, even for 17mm wheels, in the first place!
BIG-block
09.15.2011, 11:32 PM
Looks very impressive to say the least. Well done. How hard was the HPI stub axle to drill? Did you have to use a special bit to do the job? Last question. Would you consider making the same thing but in 17mm version for us that are still running 1/8th size? Would be very nice if you did it with similar off set as the stock XL setup has.
NickRummy
NickRummy's Avatar
09.16.2011, 08:27 AM
Used a carbide tip for the hole in the axle to play it safe.
Funny you ask, I'm working with someone on a 17mm version. He's wanting it to work on box the X and XL axle though so that's proving to be a little challenging. XL axle is easy, I'd just copy what I did here basically.
BIG-block
09.20.2011, 06:19 AM
Any development on the 17mm versions? I have been mucking around with RC8T (wide ones) hexes on my Savvy XL. I can either drill a 2mm hole in the hex and remove a little material from the back of the hex to make it all line up or drill a 2.5mm hole trough the stub axle. Not a fan of trying to drill the stub axle with my wonky drill press so instead I drilled a 2mm hole in the hex. Here is the result.
Best thing about this is that the offset stay the same. Not sure how well it would work on Flux or non XL axles though. Still I would like to see something purpose made like you did for the 24mm ones.
NickRummy
NickRummy's Avatar
09.20.2011, 08:22 AM
Not much progress made on the 17mm hubs at this point. Still doing some sketches. We've thought about doing exactly what you did but we're leary about the small amount of material left behind the pin? There's a few ideas we're exploring. We're trying to make something that will work on XL and non XL axles as well.
brian015
brian015's Avatar
09.17.2011, 02:03 PM
I've glanced at this project now and again - but haven't commented yet. I just looked through the whole thing again and all I can say is very nice work. You're making me think more and more about getting back to my on-hold large scale project!
-brian
NickRummy
NickRummy's Avatar
09.19.2011, 09:14 AM
-brian
DO IT! Got a build thread for it?
brian015
brian015's Avatar
09.19.2011, 09:33 AM
This one in my signature:
1/6 Losi Hummer (CC1717)
BIG-block
09.20.2011, 06:07 AM
-brian
You really have to get back into that project Brian. I was really enjoying watching everything get hand made. Would really like to see it finished.
Finnster
KillaHurtz
Finnster's Avatar
09.20.2011, 09:33 AM
Excellent part and design. :)
