pietrvds
01.15.2012, 09:08 AM
After that it was time to put the entire thing together!
when i did i encountered a problem and a big one.... the dogbones just didnt fit well they did but they where like jammed like he ll :p in the cups...
First i thought the holes were the reason and i measured everything wrong but thank god i didnt change the holes...
The reason was this, the pins in the ballends where not completely centered and straight so a bit out of center and maybe 1 degree skewed... F U CkkKkkk!!!!! CENSOR this i thought i was going to throw it throught the window but when i found my calm again i thinked about what could be done now and since ordering new bones was completely out of the question i started grinding the cups.... after grinding the cups both in the diff and drive cups everything ran smoothly...
pfjjjiiiioew.....
didnt know what i would have done if it didnt hehehehe
anyway the pics are here, i just finished the front section and added the skidplate, the shocktowers and the shocks but still have to make steerings links but after typing this i'll get on with it! ;)
compared to a baja 5b front end 8)
hope you enjoy it, it gave me headaches but hopefully it will give me some pleasure lol
cheerz!
pietrvds
01.15.2012, 11:28 AM
just for fun....
i could not resist....
mock up is cool!
don't like the bumpers rear and front 1 bit so i'll remake those!
think i'll be up and running end of next week :)
pietrvds
01.15.2012, 05:30 PM
nopes i have these...
http://fastlanemachine.net/proddetai...LM40010&cat=22
the xl hybrid bulkheads...they do state : Accepts stock gears with no modification
anyway no probz for me, they really are great pieces of art and i ordered 16x8x4 bearings from boca and they work like a charm now so no worries.
Knez
Knez's Avatar
01.27.2012, 11:54 AM
Damn, progress as i see :)
How do you like the widened truck ?
I will go back to stock wide lenght with wide axles front and keep the wide brace kit at the rear. Truck will turn a lot better this way.
It is not such a big deal but for a track with sharp turn it might be a problem.
We need front CVDs and something similar to LRP S8 BX steering knuckles.
That would be grat and nice turning radius.
Flux 5B CC 1520
1/16 Rally
My Youtube
Russian:Life and Trust is Lost Only Once!
pietrvds
02.07.2012, 04:07 PM
hellohello! it's been a while but i have some updates for you all! :)
Dejan from Alza Racing made me some custom tvp's with engravings so now it's really one of a kind and really Chunky donkey style :)
time for some advertising
they're pretty heavy but it will move i'm sure 8)
pietrvds
02.07.2012, 04:08 PM
Allmost everything was ready from that point, i just had to drill some holes to fit the center diff, battery plate, esc plate....
Then i encountered some probs with my previous center diff so i decided to make another one myself.
I used 10mm thick alu plates, a handsaw and a drill, tapped thread and this is the result, it's pretty Chunky...
offna spider diff with 500k oil.
mounted on the tvp
with the motor
overall view
then the rest was pretty simple, just had to add a battery tray, position the esc recieverbox plate and add the electronics.
pietrvds
02.07.2012, 04:09 PM
the front bumper was also a bit beefed up ;)
The upper arms are now also fully adjustable and made from 5mm rvs threaded rods and the adjustable Savage upper arms set from hpi.
after that it's SHOWTIME!
pics are a bit dark but its finished and ready to roll :)
the lexan body is from Grafil and designed for the mcd race runner.
compared to his real baja brother
and all alone in the snow 8)
YIHAAAAAAAAAAAAAAAAA i did it and i'm happy about it lolllzzzz
Took me some time but i'm glad i finished it hehehehe.
Have i run it yet? euhm you can start laughing now coz i installed the rear diff backwards so my wheels turned in opposite directions. Good thing the wheels were off the ground when i tested it so i just have to switch that diff and off i go!
pietrvds
02.09.2012, 02:52 PM
some specs:
- the weight of the car with batteries and body is 11,5kg or 25,35 pounds, my friends baja 5b without fuel is 10kg.
- the wheelbase is: 56cm and a baja 5B has a 56,5cm wheelbase.-
- width: Fr = 50cm or 19,7 inches Rear = 52cm or 20,5 inches NOTE: is use the standard Flux drive axles not the XL ones to reduce stress on the bearings and i just have long arms lol :)
vids will be made soon!
Cain
06.21.2012, 01:23 AM
how has this been holding up for you?
Looking at the pics of the servo mount, do you think someone could rig a dual servo setup?
