Rebuild kit...smoked motor
Hayden
Rebuild kit...smoked motor - 09.19.2006, 04:22 AM
Since the 1930 is not a cheap motor can you get spare coils for it? I have only burnt out one coil, in the green circle the wire is supposed to be joined “burnt like a fuse” and the red arrow is only one coil burnt.
Image Hosted by ImageShack.us
squeeforever
squeeforever's Avatar
09.19.2006, 07:19 AM
I don't think you can replace just the windings, but you I'm pretty sure you can get just the can. It might be $150 or something, but it would be better than the original price....
Hayden
09.19.2006, 08:18 AM
Does the can come with the windings? And does mike sell the cans?
sjcrss
Hyper 7 Erevo Center Diff
sjcrss's Avatar
09.19.2006, 08:27 AM
here is the email that i use when i need to talk to bk in germany...keep in mind they are 6 hrs ahead of us....
info@bk-electronics.com
Bl E-REVO
Quark 125b
Castle Creations-Neu 2200kv motor
((2s2p)(4s)
7800mah 7.4v Lipo Pack
E-Revo 1/8 scale Hyper 7 CD
http://www.rc-monster.com/forum/show...1&goto=newpost
  Send a message via MSN to sjcrss
Serum
Serum's Avatar
09.19.2006, 10:55 AM
The can is connected to the coil. They use some kind of lacquer and put them in an oven.
Did you used too long screws?
glassdoctor
TEAM FUSION
glassdoctor's Avatar
09.19.2006, 11:01 AM
Would be cool if they offer to replace/refurb the can for a reasonable price. You know they can if they want to. The cost is negligible to a manufacturer to repair something like this.
Serum
Serum's Avatar
09.19.2006, 11:07 AM
It's a pita to get it out.
With electric motors, the wattage of the motors that can be (money efficient) recoiled is getting higher with the day.
coolhandcountry
coolhandcountry's Avatar
09.19.2006, 01:27 PM
How did you smokethe motor?
neweuser
neweuser's Avatar
09.19.2006, 02:17 PM
You would think if it were too long of screws, more than one portion would be burnt up? Unless it happened at "plug in"?
sjcrss
sjcrss's Avatar
09.19.2006, 02:43 PM
that what it looks like...one of the srews made contact with the winds...
Bl E-REVO
Quark 125b
((2s2p)(4s)
Hayden
09.20.2006, 04:53 AM
Yeh I can’t find any specifications/dimensions on these motors at all.
The screws did touch the coils but only just to leave a little mark but the weird thing is the motor worked for awhile with those screws then it smoked I though if the screws where touching it would of smoked straight away. To me if there’s no specifications like dimensions/sizing it’s a design fault.
sjcrss
sjcrss's Avatar
09.20.2006, 07:56 AM
did you email Bk to see what they say.....i have hte phone # if you like, so you can call them....just let me know...
Bl E-REVO
Quark 125b
((2s2p)(4s)
Hayden
09.20.2006, 08:46 AM
Obviously I’ve opened it so I don’t know about warranty anymore, I don’t know about the phone number because I’m in Australia, I haven’t emailed them but I can.
sjcrss
sjcrss's Avatar
09.20.2006, 09:05 AM
try that first and if you need the # just drop me a pm or i can post it here...ok...I call from the US all the time to them....just to let you know...
Bl E-REVO
Quark 125b
((2s2p)(4s)
09.20.2006, 09:38 AM
The wires in the windings are coated with a form of varnish to insulate them against each other. A screw, unless turned tightly will not touch the actual wire right away - it probably ran OK for a while, then smoked when the vibrations caused the screw to abrade the varnish away.
Before mounting a motor for the first time, I VERY gently insert the screws as far as they will go until the ends touch the coils, then back off two-three turns. I mark that spot and remove them. Use the shortest one (one screw will probably hit a coil first due to how they are built) to find the exact screw length you need. You just can't forget to account for motor mount thickness (which I did once).
