Hardstyle
Hardstyle's Avatar
04.01.2009, 04:49 AM
Sry I meant in the external reservoir, where it dumps the extra oil when compressed..
04.01.2009, 04:53 AM
they are just foams to keep the oil from bubbling. I would leave them in.
Hardstyle
Hardstyle's Avatar
04.01.2009, 06:22 AM
Ok, thanks for the info. Btw Welcome back
04.01.2009, 06:37 AM
No problem,and thanks
xleonex
xleonex's Avatar
04.04.2009, 07:32 PM
ok how much for a set of those mounts! dude i want to get runnin!
xleonex
xleonex's Avatar
04.04.2009, 07:34 PM
is mike working on a set of these yet or a diffrent set up? anyone talk to him lately?
93firebird
04.09.2009, 07:03 AM
Well mine is alive, but I'm not so sure I like the noise coming from the gears upon acceleration from a dead stop. It quiets down once moving but it makes a heck of a lot of noise when starting. I checked the gear mesh and all seams well. I used a piece of of packaging board, the type used at the top of the bags your small parts come in to set the mesh.
Hardstyle
Hardstyle's Avatar
04.11.2009, 05:08 PM
Nice work 93firebird. Yeah metal spur and pinion will be a little noisy. Are you running 6s with 2200 kv? What center diff?
Are you sure that your system isn't cogging at the startup? It would explain the rough noise.
Sry guys, have to admit that my projects haven't gone any further. Still looking some extra time. Since now weather has cleared up in here cold cold Finland my other hobby has started to taking my little time
There's my DH bicycle
93firebird
04.11.2009, 05:31 PM
I took the truck to my LHS and they said the noise was normal cogging. So I am running with it. I am using a 4s 4000mah lipo for now. the diff is the center diff from the stock genesis tranny with the mxs24 which I think is from the matrix. It's a cnc steel gear with 46t. I am now running a 21t pinion instead of the 19t which seems to have helped with the cogging noise a little. I had to use a die grinder and notch the motor shaft as I couldnt seem to hold on to the pinion gear, it kept flying off even with lock tight. My mounts don't look the greatest but they are functional. Not bad for a saws all and die grinder. Maybe some day my wife will let me get a miter box with a cutoff wheel on it and the cuts can be a little straighter.
xleonex
xleonex's Avatar
04.11.2009, 05:45 PM
mike!!!!!!!!!!! make me some real mounts!
93firebird
04.17.2009, 08:32 PM
Well my Genesis cooked my MMM, I don't know if it was too much gearing or what. I was using a 19t pinion on a 46t spur and a 4s lipo it went up in flames and melted the case as well as one of the motor connectors on the esc.
Hardstyle
Hardstyle's Avatar
04.18.2009, 09:06 AM
What motor did you run? With that setup you should use something like 1100kv motor and still got speed up to 50mph. Very tall gearing imo.
Remember that the Gens diff ratios are pretty tall 26/9 so no need to gear high from the pinion, because the diffs are doing it.
93firebird
04.18.2009, 11:49 AM
I was using the neu-castle 2200kv motor that came with the speed controller
Hardstyle
Hardstyle's Avatar
04.18.2009, 11:55 AM
Ok. Sorry for your loss. Send it back to castle. they'll hook you up. Dunno if it goes to warranty though.. Next time use much smaller pinion, start like 10T. Did you check temps from the motor and batterys?
93firebird
04.18.2009, 12:04 PM
it happened on the third run, I checked on the first two runs. The third one it never moved.
