MetalMan
MetalMan's Avatar
04.08.2007, 10:58 PM
Originally Posted by BrianG
Maybe tire manufacturers should wake up and mold in some fibers right from the factory! This issues isn't exactly new...
Actually, the Proline MTR tires have internal ribbing that seems like it should reduce ballooning. My Revo has not noticed a difference in ballooning between these tires and non-MTR tires :mad:1.
04.08.2007, 11:03 PM
Yeah, they ought to mold in fiber "circles" so they don't expand at all. Ribbing helps, but the centrifugal force apparently easily overcomes the ribbing...
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
04.08.2007, 11:19 PM
Fiber mesh, all the way.
hyperasus
hyperasus's Avatar
04.09.2007, 06:57 AM
Yeah I like where Pro-Lines head was at when they added the ribbing to their new tires. But in the end all the ribbing does is make it harder to tape. The very least these companies could do is make us some tape made specifically for this . Or better yet, sell the tires with the tape already installed. Tape would be super easy for them to do.
furu
04.09.2007, 07:32 AM
The problem with ballooning tires should be solved by using correct diff oil, shock oil and a good setup for the truck/buggy/car. Adding tape or mesh to a tire adds weight, and that's usually not what you want if you're racing.
If you just add tape the tires will still be up in the air spinning and not on the ground. Having lots of power doesn't help if you can't use it correctly.
glassdoctor
TEAM FUSION
glassdoctor's Avatar
04.09.2007, 11:09 AM
That's pretty much a direct quote from Adam Drake ;) and it is true for racing.... but that doesn't apply to doing speed runs and bashing... that works on the track (short bursts of speed and power)
But at a certain speed, tires will balloon no matter what setup is on the vehicle.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
Finnster
KillaHurtz
Finnster's Avatar
04.09.2007, 12:12 PM
I was thinking about using that packaging strapping, the only thing that converned me was the glue is water based, and its also a paper based strap. Don't know what would happen if it got really wet. I was thinking about gettin some from our shipping to try out on my mashers. At least with beadlocks you can take them off and fix it if it doesn't work.
As far as a fiber strap, there is a drywall tape that is a fiber mesh about 2" wide. Its a type of fiberglass IIRC. It is heavy duty, and may work well also for belting. It is glueless, so this would need to be figured out.
The trick is to find a glue that is strong, yet flexible enough not to break with wear. I'm not sure how CA would fill this role as it tends to be stiff and brittle when cured. A polyurathane glue may be better.
Eccentric
04.09.2007, 12:50 PM
I'm going to be trying racer's tape. It's what you see them use in the pits when cars have minor contact with each other. It's sticky and strong.
Serum
Serum's Avatar
04.09.2007, 07:58 AM
at 40mph+ diffoil doesn't offer help.
BP-Revo
BMW M Power!
BP-Revo's Avatar
04.10.2007, 01:35 AM
Well, on my 18T, I went around nearly 3 times for the rear, twice on the front. One of the front's belts snapped and the tire blew off the rim. I reglued after going around 3 times...
However, you have to remember that my 18T does ~50mph and for it to go that fast the tires need to spin stupid fast, so its alot more stress.
I'd say 2x around for MT tires is fine, but once is certainly not enough.
jhautz
jhautz's Avatar
04.10.2007, 02:12 AM
Actually I think the bigger tires have more centrifugal force on them than the smaller tires. The distance from the center of rotation and the mass are the other 2 factors besides the speed of rotation that are factors when calculating centrifugal force. The bigger tires have more mass farther from the rotation center.
to make it...
or break it...
Silent...But Deadly
jhautz
jhautz's Avatar
04.10.2007, 02:22 AM
The thing I found to work the best is, turn the tire inside out. Clean the whole inside with dish soap (grease cutting kind) that takes all of the demolding residue off of the inside of the tire. Just like you do on the tire bead before you glue them to the wheel. Apply 1 layer of good quality duct tape and overlap the ends by an inch or so. Turn em back right side in and glue em up. Haven't had one fail yet after cleaning all of the silicone demolding goo off of the inside before taping it.
That mold release agent is tough for anything to stick to. Tape glue or tire glue.
EDIT: make sure the tape is wide enough to cover the whole tread surface of the tire or you will just wind up with smaller baloons on the edges of the tire where the tape missed
to make it...
or break it...
Silent...But Deadly
glassdoctor
TEAM FUSION
04.10.2007, 03:13 AM
Hey.. cool double balloon there. In all fairness to myself... :D... I had in mind 1/10 buggy street tires, not bigo monster trucks. :)
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
zeropointbug
Z-Pinch racer
04.10.2007, 03:18 AM
Yah, i would think it doesn't matter too much how big the tire is, within a relative mass factor. Look at the onroad cars, they hardly balloon at all.
