Go Back   RC-Monster Forums > Support Forums > Team Tekin
skellyo
skellyo's Avatar
04.19.2007, 12:22 PM
Since some of you haven't read what all TeamTekin has posted, here's some excerpts that should lay some questions to rest:
In reference to the Mamba Max FET datasheet BrianG posted:
Originally Posted by teamtekin
Since it appears you will tear it apart and look anyway maybe I should tell you what our fet is? I think the spec sheet will impress you. Far better than what you are looking at currently for large scale applications.
Again in reference to comparing their FET's to the MM FET's:
Need to protect ourselves a little. The others will find this fet also I am sure. I will tell you the continuous drain current is higher, Rds on is lower, gate charge is lower and pulse current is unbelievable. Try over 250A vs 106A. Spendy little buggers however.
Referencing the number of FET's and heatsinking:
Part of the of the magic is that we use 2 boards, half the current in each one. Shhhh Super heavy copper, multi layer, designed to reduce all trace lengths.
R1 has 24 fets, R1 rpo has 48 fets. We thought the Mt would need even more, but these fets are proving to be pretty amazing. It also helps to have the high voltages. Voltage is our friend and current is a beotch. Power =VI and more V reduces the I for a given power level.
Also our solder post make really good heatsinks because they are soldered to the power planes. It is basically a copper block and we can pull the heat from anywhere. We will likely flip it over and heatsink it on top just to make sure we have lots of head room. It really is a big block of copper and we can pull heat from the entire mass.
In reference to the BEC:
We are just starting to test with the larger voltages. 5s should not be a problem, but like all speedos you will need a seperate BEC. Darn hard to step down that much voltage and be able to supply any current.
In reference to 6S operation:
Pretty much everyone is using 30v fets. 6s is getting pretty close and does not leave much headroom for voltage spikes. Some fets handle over voltage better than others. The manufacturers do not address areas beyond the specs so you just have to test them and see. So far these fets are incredible. The better the circuit the lower the spikes and the better the chances, but braking battery regen can still be an issue. If the battery is full and will not accept the regen charge, the voltage can go really high, really fast. Just like motor flyback current that needs a diode or a rectification circuit like our G11, if you do not give the current somewhere to go then voltage spikes can be off the map.
We will know shortly. I am pretty excited about this market and with everything else finishing up we have time now to look at some new challenges.
IF you really need 6s or more and this will not handle it, we will build one that does. That is why we are here learning.
Finnster
KillaHurtz
Finnster's Avatar
04.19.2007, 12:46 PM
Missed that little gem RE: Fet specs. :) Thanks to Brian for forcing the hand! Does that suggest the Pro ESC could be rated for 200A+ then (depending on the other components)?
Would explain the price diff on the R1 pro vs MM. Makes you wonder what the Pro could do itself, as the doubling of the Fets from the r1 to the Pro is suggested to be enough for the MT. Again, pushing 6S seems very possible on man brakes. Theoretically perhaps on the MM if the current could be kept low enough, as discounting other components like caps (ie not in real world in other words. I'll have to flip back to the MM fet thread on this.)
Its also going to be interesting to see how the market breaks for the ESCs. CC is aiming for the low end, while the Tekin will be higher end. Its going to be hard competition vs a low cost competitor, so long as both are going to be capable enough. Look @ walmart for example, low cost but lower quality (not that I would call the MM low quality in and absolute sense.)
04.19.2007, 12:26 PM
That's a really nice compilation of all the important points!
Serum
Serum's Avatar
04.19.2007, 12:32 PM
Great post Boy..
I thought about compiling since some of us apear to be terrible readers.. :p
captain harlock
RC-Monster Captain
captain harlock's Avatar
04.19.2007, 02:37 PM
TeamTekin is merely aiming for winning REAL races and Castle Creations wants to satisfy the basher a bit more than the racer.
What I really liked about tekin is that they said many times that they want to develop an esc and then push it to the limits, find a weak spot, modify it, push the thing to the limits again, find the weakest point again, modify it again and blah, blah,blah.....
They're very comparable to UE ( seeking absolute perfection, but it costs lots of money) and FLM ( building super tough parts for humble prices to satisfy the general RCers).
Nice to meet you!
crazyjr
crazyjr's Avatar
04.19.2007, 03:36 PM
You can't have it all, either compromise or pay the piper. I personally wouldn't mind paying the money, if it delivers everything we want
coolhandcountry
coolhandcountry's Avatar
04.19.2007, 03:17 PM
Maybe it was the problem of 5s and hi amps.
It may survive better with 5s on a lower amp motor.
AAngel
04.19.2007, 03:50 PM
In my discussion with the guy at Tekin, all was looking ok, until i brought up the 120A spec from the pdf manual. That's when he said that they had revised the specs, but hadn't posted them yet. They are still working on it though. Unless I misunderstood him, he said that the R1 pro was not shipping yet, as they are still working bugs out.
captain harlock
RC-Monster Captain
04.19.2007, 04:07 PM
Towerhobbies has them listed as "order pending".
It's like the president actually said in another forum that he won't release the esc until he makes sure that it's going to deliver what it is rated for.
Nice to meet you!
jollyjumper
RC-Monster jumper
jollyjumper's Avatar
04.27.2007, 02:08 PM
any of you guys got more news?
thanks, mike.
losi 8ight-t
xray xt8
gixxer
gixxer's Avatar
04.28.2007, 12:27 AM
http://www.teamtekin.com/manuals/R1Manual.pdf the manual is now online, I think that means we are getting close. :)
Kyosho SC, tekin rs, D3 17.5
Hyper 9e, mmp,tekin 1900kv
AAngel
04.28.2007, 01:09 AM
That's the manual that I quoted specs from when I called Tekin. I don't know how long it's been there, but at least since the day I posted last in this thread.
I'm waiting for the MT version.
Sower
Sower's Avatar
04.28.2007, 01:10 PM
Anyone notice that the R1Pro says it's rated for 5s lipo? I thought they said only the MT would get up to 5s.
gixxer
gixxer's Avatar
04.28.2007, 01:27 PM
The prez, said it would do 5s if you disabled the bec.
jollyjumper
RC-Monster jumper
04.28.2007, 01:30 PM
does the r1pro work with neu motor?
losi 8ight-t
xray xt8
