ffactory666
10.26.2008, 01:37 AM
Nice mate , good to see the MMM is running cool with the new firmware and no external bec .
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
10.26.2008, 03:32 AM
Well got pizza for lunch and went and did some more jumping/running in the backyard and after about 2 hours of more running disaster struck .............. I hit a jump wrong which sent the buggy flipping towards my son (21 months) who was playing in little sand pit and the buggy struck him in the head and split his head open. So trip to the hospital for the poor little guy. He was ok, but lost alot of blood.
The MMM is still going strong though, it seems to have more punch and better throttle response with the new firmware.
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
tc3_racer_001
tc3_racer_001's Avatar
10.26.2008, 07:21 AM
more punch- how about RIDICULIOUS PUNCH. 100% seems to do nothing...
i can wheelie with 100%. struggled with 0 before. (V2 BTW)
good to know everythings good. pitty about your son! hope he gets better!
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
DRIFT_BUGGY
10.26.2008, 06:24 PM
My son is fine. When I running around the yard and I flip over, he gets real angry with me if I go and flip the buggy back over as he wants to do it. He always comes with me to the track and stands in pit lane watching me.
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
DRIFT_BUGGY
10.26.2008, 10:36 PM
Well got to go down to the track today for the first time in about 2 months. First time I have been to the track running a different setup (shocks changed, diff fluid now 7/10/3) but I ended up taking my old bold tires down to the track. I got 35 minutes out of the first battery before LVC kicked in (16.4V) and highest recording temp for the 1st run was Motor - 170F, Battery 120F and ESC was 135F. ESC was running 135F as I didn't realise that a twig got jammed in the fan and the fan was working. Took the twig out and fan starting going again. ESC temp went down to 125F once fan started working. It was hard to say if the setup was great as bold tires didn't help but even with the bold tires, it seemed to handle pretty good.
I let everything cool down and then went out for another run. Temps got a little hotter this time, Motor - 180F, Battery - 120F and ESC - 130F but that might be becuase it was now the middle of the day and was a pretty hot day. Bold tires also don't help. After 35 minutes I noticed that one of the tires was unglued but I thought that the battery would ran out soon so I kept on going. Flat out down the back straight lost control and hit the wall pretty hard and ended up stripping the thread that the screw goes into hold down the turnbuckle on the spindle. Didn't matter, didn't ruin my day as that was probably the most fun I have had with a R/C. Castle has done a excellent job with this new firmware. No issues at all and it doesn't look like stopping at all. So nice to not have a ext. bec. on anymore.
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
tc3_racer_001
10.27.2008, 02:08 AM
good to know that im not the only one with a hot motor (170+F). although im getting 160+ after only 6 minutes. in the mains though it doesnt seem to get past 175 before stablising. mind you, it was a 35C day in the shade!!
hyper 8.5 pro SOLD!
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
DRIFT_BUGGY
10.27.2008, 09:09 PM
Got to go to the track again today. I put some new Losi Step Pins on, what a difference it makes having tread, doesn't feel like you driving on ice.
1st battery went good, got 37 minutes on it before LVC kicked in. Temps were; Motor - 175F, ESC - 130F & Battery - 130F.
I let it cool down and then ran the next battery. After 22 minutes I bought the buggy into the pits to check the temps and the motor was 195F (ESC 135F and Batter 120F) It was another hot day but I have never cleaned the motor/bearings. So ill clean and check over the motor and hopefully get another run tommorrow.
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
tc3_racer_001
10.27.2008, 09:55 PM
jeez, and your in sydney! im screwed in brizzy running a hotter motor, smooth can, heavier car and ambient temps cracking 40 regularly in summer!!!
hope you get it under control, sounds like alot of fun though!
hyper 8.5 pro SOLD!
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
DRIFT_BUGGY
10.28.2008, 12:25 AM
Im in Central QLD. Surely it can't be from running thicker diff fluid in front and rear.
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
ffactory666
10.28.2008, 02:04 AM
Have you tried going up one tooth on the pinion to see if the motor temps come down , sounds like your undergeared .
DRIFT_BUGGY
10.28.2008, 03:28 AM
No, i'll try that tomorrow. I was running a larger tooth before I changed all the settings (MMM settings/diff settings etc.) which was when I 1st built it.
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
DRIFT_BUGGY
10.29.2008, 01:43 AM
Well put the 14T pinion in and after 15 minutes the temps of the ESC was 140F and the motor 185F. I then set the punch control back to 50% and put the 13t pinion back in and after another 15 minutes which is when the lvc kicked in the temps were 130F for the esc and 175F on the motor. I'll hopefully get a chance to run another battery and check the temps again. Surely the thicker diff fluids aren't making the motor run hotter. I only went 2000wt thicker in the front and 1000wt thicker in the rear
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
ffactory666
10.29.2008, 05:00 AM
Never heard of diff fluids doing that .
It's getting hotter in Melbourne and was 28 today my temps went up about 10 degrees across the board from last run but all well within acceptable temps .
I run medium timing on my Medusa as i was told by others and Medusa recommends medium timing on 4 pole motors so maybe you can try that.
Check your bearings in the motor as well and your whole driveline as something could be binding .
With AKA couldn't find any in OZ either ,A Main is the best bet or Imapkt ( i do most of my business with them as well )or try ebay for a bargain . Kyosho MP9 comes standard with medium compound City Blocks so look for one that is being parted , there a few at the moment
DRIFT_BUGGY
10.29.2008, 06:41 AM
I was told with 'D' Wind motors to run them on low timing and 'Y' can run medium+
I clean my bearings yesterday and put oil on them. Might check out the drivetrain but all seems fine. Might purchase a 12T and see what happens then. 13T (what I am not running) seems just right though (41mph) Know of any where in Australia that sell Mod 1 pinions?
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
ffactory666
10.30.2008, 05:49 AM
Sorry , wish i did .
I have bought all mine from Mike RCM or at Impakt for Robinson pinions .
I have from 14t - 21t but destroyed my RCM 15t last week .
