E-Traxxer
08.03.2008, 04:14 AM
Originally Posted by azjc View Post
you might want to go with the 1521 instead there is a member on the board who tried a 1527 in a Savage and he didnt like it ...saying you couldnt contol all of the power
here is a link to a post he started
http://www.rc-monster.com/forum/show...light=neu+1527
Well, I already have the 1527 ordered and they are making it for me so I don't think I can turn back now. My truck is most likely going to be heavier than his so maybe it'll be able to handle the power better. I can also have the slipper set a bit looser than super tight (so just tight). If it ends up being too much to handle, I can order a 1521... but hopefully it won'tbe!
azjc
08.03.2008, 04:36 AM
I did a forum search on the Neu 1527 and a lot of posts came up...there was a lot of info if you are intersted
E-Traxxer
08.03.2008, 07:22 AM
Thanks for the heads up.
E-Traxxer
08.04.2008, 11:37 PM
So.. plans have changed, again!
Why can't I just stick with one plan?
So I'm changing the design because a few reasons:
I don't want the batteries to stick out of the sides of the chassis
The brake system that I had planned was just a bit weak
The design that I had was a bit too complicated and would be extremely hard to put together/do maintenence on.
I have a new design in my head, and it is a little bit different, but not by much. I am also going to be using this new platform to create a Savage/Truggy hybrid as another project as well.
I'm throwing myself on a rollercoaster, but this should be the last one! I hope. I just want to get it right the first time, as I'm a bit of a perfectionist at times...
bl-is-future
bl-is-future's Avatar
08.07.2008, 08:36 AM
yep i run the genesis body on my flm and the front is just behind the bumper as is the rear. So this should give you plenty of leeway for your chassis.
edit- look at my avatar, that is the genesis body on the FLM conversion. The rear is just as close to the bumper.
E-Traxxer
08.07.2008, 08:44 AM
Looks like a Genesis Body is on the top of my list now, then.
Thanks again guys.
bl-is-future
08.07.2008, 08:51 AM
oh forgot to tell you though that escalade body is the longest. That is the style on my truck link here - http://www3.towerhobbies.com/cgi-bin...2&I=LXPCG5&P=K some genesis bodies are shorter. Just look at the lengths to see how shorter.
E-Traxxer
08.07.2008, 09:12 AM
Oh alright, thanks for the info.
I'm also going to post what I have for the speed calc now, mainly for my own records, since things tend to get lost on my hardrive... (It's those cyborg lawn gnomes with USB connections, I say!)
Differential Ratio: 3.3076923076923075
Transmission Ratio: 2
Other Ratio: 1
Spur Tooth Count: 38
Pinion Tooth Count: 14
Total Voltage: 44.4
Motor KV: 1150
Tire Diameter (inches): 6.9
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0
Spur/Pinion Ratio: 2.71 : 1
Total Ratio: 17.95604 : 1
Tire Circumference (inches): 21.68 inches (550.6 mm)
Total Motor Speed: 51060 RPM
Vehicle Speed: 58.37 mph (93.77 km/h)
Estimated Adjusted Speed: 54 mph (86 km/h) - 8% loss
Effective KV Value: 1150
KT constant: 1.18 oz-in/A
Hmm, I just found this body for the MGT http://www3.towerhobbies.com/cgi-bin...?&I=LXFUL9&P=7
It says it's 20 inches (shorter than the Cadillac for the Genesis) but also says its 556mm (longer than the Genesis one).
Hmm...
bl-is-future
08.07.2008, 09:46 AM
i dont listen to descriptions usually. the specs say it is 20" and the one i linked is 20.5" so very little difference
aqwut
Brushless Heavy Weight....
aqwut's Avatar
08.11.2008, 10:58 PM
Awesome project you've got going there dude!!
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
E-Traxxer
08.12.2008, 12:03 AM
Thanks!
I'll try and see if I can finish the drawings tonight. School is starting up again soon for me, and I've been trying to squeeze every last bit out of my summer.
E-Traxxer
08.14.2008, 05:52 AM
Update! (finally )
I finished the basic drawings of my new design. It took way too long, probably because I changed my mind a few times.. again (this is the last one, I promise! I'm fully satisfied with this). I have to change/add a few things (front kickup being one of them), but this is the basic layout of everything. I still have to wait on a few things in the mail before I can add the radio tray, brake mounts, rollbar, and a few other things. I will also take out much of the "TVP"s once I get all of that other stuff done, to significantly lighten it all up. There's more good news: It will end up being only 10mm longer than an FLM kit with this design, and I'm sure the CoG will also be much lower.
Without further ado, here are the pics!
Trimetric:
Rear:
Side:
Top:
Hope you guys like it! I know I do!
Byte
08.14.2008, 06:17 AM
That looks damn nice!!
Nice project!
BitHed
01.04.2009, 12:45 PM
...very cool...i DO like it...so did you get your 2008 resolution done? :D As the first post of 2009 I ma looking forward to hearing how its going...Thanks for all the work you have out into it and thanks for letting us watch as you go along...An education and an inspiration all at the same time...Great stuff...
E-Traxxer
06.26.2009, 07:21 AM
This project is not done but I am determined to finish it very soon, I have the final design in the works and will hopefully have the drawings done in a week. This new design is definitely the last one, and also the best IMO. It is still going to be run on 12s with the NEU 1527 2D and will have the same wheelbase as the Savage XL. It will be overkill. It will probably kill someone. It's out of my hands now.
Question though, does anyone think that the slipperential will be able to handle this power? I plan on using it but I'm scared... so scared.
