Thread Tools Rating: Thread Rating: 10 votes, 3.60 average. Display Modes
11.06.2008, 07:10 PM
Well, I know someone who wouldn't mind an extra Spek receiver! Gotta use the remaining 24 model memory slots on my DX3r for something...
Sammus
Sammus's Avatar
11.06.2008, 07:12 PM
My problem seemed like the batteries voltage was dropping so far it reset the rx (i could see the rx light go off and watch it reset), but i tried all kinds of high powered lipos and stuff too, the a123 were just the standard setup, and it happened with the motor not connected to anything as well - not even a pinion on it, I'm pretty sure A123 cells are up to spinning an unloaded motor without dropping below 1V/cell lol... I can't figure out what it is, and havent to this day. I've used the exact same setup in other cars without problem, it is really really baffling. Like I know there is something I'm not thinking of, and its really frustrating lol.. oh well.
11.06.2008, 07:14 PM
A few questions:
- Were you using a BEC or Rx pack?
- Were the rx pins dirty? Or, they may have a cold solder joint and making/breaking contact.
- Is the antenna sound? I had a Spektrum antenna that was flaky and had odd stuff happen until I replaced it. Was a PITA to solder though because of some coating on the PCB.
brushlessboy16
brushlessboy16's Avatar
11.06.2008, 07:17 PM
I might know someone who could use cash or something for trade- just shoot me a pm
Sammus
Sammus's Avatar
11.06.2008, 07:23 PM
A few questions:
I tried an external and the internal BEC, and 4 different receivers. I don't own an Rx pack but I'm thinking I'll build something and try it soon. I'd hate to have to run an Rx pack though, and I still can't believe 4s1p drop that much with zero load... it actually seemed to glitch more when I was testing it unloaded, but it could just be my frustration imagining things lol... meh more testing when I have time.. I'll probably make some thread about it if I ever succesfully figure it out haha
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
11.06.2008, 07:34 PM
Motor wires, they are 7 1/2'' long right now. i want to shorten them to like 2".
sorry about that vague post
2"? Is your esc touching the motor or something? I bet you will have trouble mounting the esc flat. Have fun holding the motor in place while changing the gearing.
Generally, shorter is always better, though it's not really practical to shorten 10ga wires that much, unless you have space issues in your vehicle otherwise. The worst things that could happen if your wires are to short is if you decide to put the motor system in a different vehicle and suddenly the wires don't reach to the esc. You'll have to solder on an extension. This is why I prefer motors with solder tabs, in which case you don't need to worry about over-shortening the wires. In fact, I just decide to rotate the MMM 90 degrees in my 8ight and even though the MMM bullets only moved an inch away further to the motor, the wires had to be about 2" longer just because of the angle required to bend the wires.
Area 52 Ranch Raceway
T.R.C.R.
brushlessboy16
11.06.2008, 07:57 PM
No the esc doesnt touch the motor, and no its not a problem mounting the esc FLAT on the chassis behind the motor. its easy enough to solder extensions on if need be- with me being broke, i dont see another car in the near future anyway.
brushlessboy16
11.15.2008, 01:16 AM
Well my V3 should be here by monday. but i Think I eliminated the glitching problem
Spektrum Rx- I got from a trade for a charger, and some miscelaneous stuff
Module- I payed 60 Bucks for. So now im in the 2.4ghz club and I like it soo far.
And I just got done shortening the motor leads down to 4 inches. Esc will be mounted behind the motor on the chassis.
brushlessboy16
12.09.2008, 04:39 PM
Hey guys a bit of an update
Just ran the truck for 20 minutes, all wot, jumping speed runs etc.
at the end of the pack the motor was 110* esc was 120* and zippy batt was at 115*
This was geared for 43mph on 4s lipo :)
SteGra
12.09.2008, 04:48 PM
What is your gearing?
How does the Neu-Castle compare to the same Neu motor (performace-wise)?
Sorry for the questions, if they've already been answered in earlier posts but I am getting dizzy going through the previous ten pages of posts.
brushlessboy16
12.09.2008, 05:10 PM
Gearing is 16/66
for 43mph
I have never run the real neu, so I couldnt tell you
E-fanatic
Brushless only!
E-fanatic's Avatar
12.09.2008, 05:23 PM
I am having some heat issues with mine. Geared for 38 in an e-revo I am seeing 170+ on the motor. It has lots of power though!
brushlessboy16
12.09.2008, 05:28 PM
what are your settings on the MMM, what motor do you run
brushlessboy16
01.08.2009, 09:03 AM
Update:
All slotted rotor-motors(say that 5 times fast) Will be hard to turn by hand.
The maximum Shaft play is approximately 1-2mm
SpEEdyBL
SpEEdyBL's Avatar
01.09.2009, 02:28 AM
To clarify, the rotors are not slotted, the stators are...
T.R.C.R.
Tags
1515 1y, brushless, castle neu, mamba monster, mmm
