squeeforever
squeeforever's Avatar
04.03.2007, 06:36 PM
I don't know, perhaps he found it easier to just make the plates thicker. It basically does the same thing. Thicker plates or thicker x-braces; there both gonna make it stronger, but only one is probably needed. Anywho, they do sell the spairs actually. I noticed that earlier today.
Nick
COOKIES!
Nick's Avatar
04.04.2007, 05:10 PM
I'm really happy the plates are finally thicker on the GorillaMaxx. Think I will get one for my new Maxx I'm doing.
Argh, why have they changed the mount, it's not adjustable anymore... hmm.
~ Nick.
Sylvester
Sylvester's Avatar
04.04.2007, 05:23 PM
The motor mount isnt bad, but the price is horrid.
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
Nick
COOKIES!
Nick's Avatar
04.04.2007, 05:35 PM
Yikes didn't see the price. I really think the mount is a step backwards. You can't adjust it as much and you can't mount twin motors.
I could hack up a stock one to look like that for about £5.
~ Nick.
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
04.04.2007, 05:45 PM
I agree, the motor mount now looks like a stocker, with half cut off. They should have made it the exact same as before, except mount it to the transmission case, IMO.
I just want to get my truck project running, spring is here and i am eager to play with it. There is one thing i don't like about the FLM chassis, the battery mounts. I could mount underneath, but my packs would take a beating.
Dafni
Dafni's Avatar
04.04.2007, 06:16 PM
The x-braces are also stronger, because they no longer have the milled slots on the underside.
zeropointbug
Z-Pinch racer
04.04.2007, 07:10 PM
How do you know that about the milled slots Dafni?
Is the FLM chassis compatible with the RC-Monster extended center CVD's?
skellyo
skellyo's Avatar
04.04.2007, 09:01 PM
The FLM chassis includes an extended CVD for the rear. You can use a regular MIP center CVD in the front.
Dafni
Dafni's Avatar
04.10.2007, 08:49 AM
The Monster told me :)
coolhandcountry
coolhandcountry's Avatar
04.04.2007, 07:14 PM
I never had a problem with that part of the braces bending. I had the problem
of right in front of the transmission mounting spot. It is designed like a y
and that y allows it to bend easily. I think it will suffer from same weak spot.
Peace!
Country
Help support the
Rc-Monster
Buy here
04.07.2007, 02:33 PM
Have you considered a race-bomb chassis? Its half way between an FLM and G2/3 type chassis, not sure of the price though.
Superemaxx89
04.08.2007, 06:15 PM
What ever happened to the idea of weight savings? Now that the chassis are thicker, the motor mounts are heavier (than previous gen gorillamaxx motor mount), less milled slots...I can only imagine the weight gain on these chassis pushes this new Generation of gmaxx wall past the weight of stock.
coolhandcountry
04.08.2007, 06:22 PM
I don't think they are going to be much stornger either. That is the bad thing.
Peace!
Country
Help support the
Rc-Monster
Buy here
04.08.2007, 06:29 PM
As with everything in life, they had to make a trade-off. The chassis is now slightly thicker = slightly stronger, and only a little bit heavier than before. It will still handle better than any stock type chassis due to the lowered CoG. I would have thought making the chassis from 7075 alloy would have been the best bet- much stronger but same weight as before, although a bit more expensive..... whatever.
coolhandcountry
04.08.2007, 06:38 PM
They made the chassis plate thicker for little stronger. The problem i see
is they didn't fix the x braces where they bend. That is my complaint.
Peace!
Country
Help support the
Rc-Monster
Buy here
