RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
08.17.2005, 08:06 PM
120 isn't hot at all. Nice truck, tomato!
tomato
tomato's Avatar
08.17.2005, 08:30 PM
Good, because now I'm going to get it hot and run some bigger pinions. What would you think is the hottest I should let it get?
RC-Monster Mike
Site Owner
08.17.2005, 09:26 PM
keep it below 180 or so and you will be fine.
rchippie
rchippie's Avatar
08.17.2005, 10:08 PM
Hi Rob
If you clean your foams with reguler gojo or orange gojo( none gritty) hand cleaner. You will get better traction. We have used this for years in oval racing. Just rub it in real good & then wipe it off real good thaTS IT. If you have any ? you have my #.
REAL MEN RUN BRUSHLESS
JOHNNYMAXXIMA
RC-Monster Dual Brushless!
JOHNNYMAXXIMA's Avatar
08.19.2005, 02:26 AM
Originally posted by Promod
I tried foams but could never get them to hook. Anything over half throttle and it would 360. But you could have better luck with them.
Thank you,
Promod
Hello Promod,
What kind of tires did you end up using to get it to hook up?
I have that same problem with my dual BL Maxx. I have a spool in the rear right now and I am going to take that out because I think that will help it to track straighter under acceleration.
Thanks.
RC-Monster Mike
Site Owner
08.19.2005, 06:21 AM
Lose the spool for sure, Johnny. Any small diameter difference between the tires will cause it to pull to the opposite side. A diff is what you need to keep it straight(and a strong steering servo with a stiff servo saver).
Promod
08.20.2005, 08:06 AM
Mike's right loose the spool. Any on-road tire works great. Also have good luck with bowties,paqman,and nubz.
Thank you,
Promod
