Go Back   RC-Monster Forums > Questions and Answers > Pre Sales Questions
Dafni
Dafni's Avatar
09.15.2005, 02:41 PM
Agree, if you don't want to change the rubbers anyway, a small drop of C/A glue will take care of those screws (I imagine :) )
You're welcome Gusti.
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
09.15.2005, 05:07 PM
The Cheyenne wheels are the ones I described to you on the phone, Gusti. These are the wheels I modify to make then narrower, which make the 40 series Bowtie similar in size to the standard bowtie when mounted, with a lower sidewall. These are the ones I was suggesting for your son, as he seems to like the Chrome look(I like these wheels myself).
Serum
Serum's Avatar
09.15.2005, 05:11 PM
@mike, you got my cheyennes on time as well?
and hava you got pics of those tires when modified Mike?
coolhandcountry
coolhandcountry's Avatar
09.15.2005, 05:15 PM
On the 4o series. You can mount a set of traxxas 3.8 size tires to them. Just to let you know. Not sure if any one else has done it.
Peace!
Country
Help support the
Rc-Monster
Buy here
Serum
Serum's Avatar
09.15.2005, 05:20 PM
It's tight isnt it?
coolhandcountry
09.15.2005, 05:33 PM
No not really. Not on the tires i did. The tires are light to. I use them to shed some weight on truck. I wish i had duct taped them though.
Peace!
Country
Help support the
Rc-Monster
Buy here
nitrostarter
nitrostarter's Avatar
09.15.2005, 07:38 PM
coolhand- do you have any pics of your 40 series wheel with a 3.8 tire?
N. Rustler conversion
coolhandcountry
09.15.2005, 08:00 PM
Sure do. I had to take it but that ok.
Peace!
Country
Help support the
Rc-Monster
Buy here
RC-Monster Mike
Site Owner
09.15.2005, 08:32 PM
Yes, Serum, I did get your wheels. I am working on some pictures of the modified wheels and tires(need batteries for the camera). I will post them when I get them done.
nitrostarter
09.15.2005, 08:41 PM
It looks like the wheels might be a bit too wide for the tires but the smaller tires keep the weight down. Not bad at all though.
coolhandcountry
09.15.2005, 09:12 PM
If you run the wider rim. It pulls the bead from the tire some. The up side to this is that the tire does not slide from side to side. It handles fantastic. They are the best handleing tire i have. They have like zero roll cause they are pulled apart. Hard on the glue though. :D
Peace!
Country
Help support the
Rc-Monster
Buy here
gusti
10.14.2005, 11:36 AM
Guys
Today I got the wheels from Dafni, he did a fantastic glue job for me. Thank you Dafni.
No I have mounted the dace on the wheels, this works pefectly. Than I tried to mount the complete wheels on the truck. This is impossible.
The reason is very simple. I am using the 8mm UE CVD's. So the CVD has a 5mm winding with a 10mm screw nut. So the diameter outside of a 10mm wrench is 14.2 mm, but the diameter of the hole from the dace adapter is 12.8mm. For this reason I can't tighten the nut.
Guys I had so much misfortune with this supermaxx, this is unbelievable. Does somebody of you have an idea how I can solve this problem.
I went to a special screw shop and was asking for a 5mm winding nut with 9mm outside diameter. But this is not available, because the dealer told me such a nut will not hold.
Thank you for your support.
Papa
Papa's Avatar
10.14.2005, 12:03 PM
My understanding is that this is a common dilema. I think you are saying that there is not enough space to get a socket wrench on the nut? If so the remedy is to grind away enough material from a dedicated socket, to permit space.
coolhandcountry
10.14.2005, 05:11 PM
I have one thing to say. Grinder.
I took a ten mm socket to a grinder and it fits great. I have not broke the socket either. I hope this helps. I run the dace adapter with 8mm ue cvds.
Peace!
Country
Help support the
Rc-Monster
Buy here
Serum
Serum's Avatar
10.15.2005, 03:29 AM
I use this to tighten the nuts;
